Post by daglad on Nov 14, 2011 21:16:06 GMT 1
Before i bray 7 bells of S%&t out of the swing arm pivot anybody any advice as how to pursuade the it out of the frame Its typical all the rest came out easy peasy oh hum
Post by Shytalk on Nov 15, 2011 9:11:49 GMT 1
As the engines out, try boiling a kettle and pouring it over the metal, you may well end up damaging the pivot bolt though if it is stuck fast, I'll have a spare knocking around if you nned one.
Post by daglad on Nov 15, 2011 13:34:58 GMT 1
Thanks mate i will have a go with the kettle, i knew it was all going far too w :-/ell
Post by looey on Nov 15, 2011 14:05:30 GMT 1
What's stuck ?.
Is the pivot bolt stuck in or is the pivot bolt out and the swinger won't come out of the frame ?.
Post by daglad on Nov 15, 2011 18:31:49 GMT 1
I have loosened the nut no problem but when i tap the actual spindle to feed it through the frame/swing arm/frame it won't budge
Post by billy on Nov 15, 2011 20:16:22 GMT 1
I had that problem on a 125LC, thing was stuck solid in there! I ended up giving it a couple of good bashes with a plastic hammer.
Post by paddyontour on Nov 15, 2011 22:08:42 GMT 1
I had exactly the same problem when I went to refurb the back end on my F2... the whole lot came out real easy, too easy I thought... then I got to where you are and couldn't for the life of me get spindle out... - brute force & a bit of ignorance done it in the end ;D I was hitting it so hard I was worried I was gonna wreck the frame!
Post by daglad on Nov 20, 2011 17:25:58 GMT 1
It's out! Bloody hell it was stuck, i need a new pivot bolt but i think i got away lightly, i really had to whack it
Post by paddyontour on Nov 21, 2011 9:54:20 GMT 1
Nice one - brute force & ignorance got there in the end then eh ;D
Post by rdorvfr on Nov 29, 2011 4:46:17 GMT 1
There is only 2 types of hammers - big ones and bigger ones. Glad you got it sorted
