Post by adamp2006 on Nov 13, 2011 16:43:55 GMT 1
So i know its been a while since i removed seals from a pair of normal forks and all the ones when i did my mechanics course had been out so many times they fell out in a strong breeze but i can't for the life of me get the seals out of these LC forks for the life of me..... Any one got any tips ? i tried removing the clip before i pulled the stanchions out in the hope the seals would hitch a ride on them but no, they r stuck fast
Post by lcowner on Nov 13, 2011 17:00:48 GMT 1
have u tried levering them out carefully with a flat screwdriver?carefully!!!
Post by adamp2006 on Nov 13, 2011 18:12:41 GMT 1
Yep that was my first solution , placing a rag between the screwdriver and the leg to protect it
Post by adamp2006 on Nov 13, 2011 21:33:57 GMT 1
Yeah it looks like the bush on the lc is in the leg rather than fitted around the stanchion, i'm not sure i have anything thin enough to get up the screw hole and long enough to get to the seal.... , its worth bearing in mind tho thanks headcoats
Post by rabbit57 on Nov 13, 2011 22:19:22 GMT 1
Could try putting the end of the stanchion in hot water to expand it and lever seal out.
Post by Deleted on Nov 13, 2011 22:30:12 GMT 1
when i did mine, you would swear they were not meant to come out, being gentle got me no where, i ended up using a small screw driver and hammered it in till it bent the metal outer ring on the seal,but it did mark where the new seal had to fit in, i ended up using my dremil and smoothed it out,hasnt leaked yet, you could try getting a nail and rounding off the point and hitting that in,once the metal ring on the seal is bent, they come out easy, but still be careful,, as i said this what i did and it worked, might not be everyones cup of tea though.
Post by mellow on Nov 13, 2011 22:57:24 GMT 1
i turned my fork upside down then poured boiling water around the outer fork leg area wher the seal sits
Post by adamp2006 on Nov 14, 2011 18:31:58 GMT 1
Boiling water u say..... interesting, and a good excuse to have a cup of tea at the same time, thanks guys i will give that a go tomorrow
Post by mellow on Nov 14, 2011 19:45:40 GMT 1
hope u got a big kettle ;D u need quite a bit of water and put it str8 on as soon as it boils
Post by marauder2011 on Nov 14, 2011 22:02:06 GMT 1
try hotair gun around the seal area should do trick.
Post by Deleted on Nov 14, 2011 22:25:26 GMT 1
once its boiling hot etc, what do you pry it out with? does it come out easily,thanks
Post by mellow on Nov 14, 2011 22:44:39 GMT 1
if i remember correctly......was a few years ago ...and mines an F2.....think i used a screwdriver and yes it came out a lot easier
Post by Deleted on Nov 14, 2011 23:08:02 GMT 1
thanks mellow,hopefully i wont need to do it again, my first attempt was a disaster,broke 2 screw drivers trying to pry out, then finally hammered one in and got it out, put in new seal and it got caught up on a small sharp bit and ruined seal, waited a couple of weeks for new seals ,then got it out again with the hammering screw driver in method ,deburred and sanded smooth and put in new seal, so far it hasnt leaked and i have rolled it down our little hill testing brakes ect, with no motor in it, neighbours must think im strange, at least i didnt make revving noises will i did it.lol
Post by billy on Nov 17, 2011 4:43:20 GMT 1
When I did the 125 forks I had to cut the bloody seals with a dremel. Took me ages but eventually they came out. PS: If your new seals has a metal outer surface, (sometimes they have rubber here just like the inside of the seals) then you should really use some sealant between the seal and fork leg so that the oil doesn't sneak out past the outside of the seal (hope that makes any sense lol). Just make sure the sealant can withstand the fork oil you're gonna use.
Post by rabbit57 on Nov 22, 2011 22:22:47 GMT 1
Boiling water u say..... interesting, and a good excuse to have a cup of tea at the same time, thanks guys i will give that a go tomorrow Did you get your seals out?
Post by ianboom on Nov 23, 2011 19:44:46 GMT 1
Post by rabbit57 on Nov 24, 2011 0:46:21 GMT 1
Looks like a handy bit of kit,reasonable price too.
Post by Norbo on Nov 29, 2011 13:41:35 GMT 1
well you cant have anough tools and thats one i dont have . i big screwdriver is what i use but not allways the best tool.
Post by adamp2006 on Dec 7, 2011 19:46:25 GMT 1
I did eventually get them out, went and annoyed my old tutors to use all their tools in the work shop, a vice a pry bar and a chisel were used but they eventually came out with very little damage so i just have to mirror polish them now and then start rebuilding them while the wheels and yokes are off to the powdercoater
