Post by fatfredfaefife on Nov 13, 2011 13:35:12 GMT 1
Hi All Started stripping my 31k YPVS, this is the rear calliper is it the correct one or off a later version, can some please let me know so I can buy the correct piston & seal kit. thanks [/img] Attachments:
Post by LC_BOTT on Nov 13, 2011 14:28:45 GMT 1
It looks standard to me, just the same as the one on my 31K.
Post by Tone on Nov 13, 2011 17:09:07 GMT 1
Looks like the same one as on the rear of my 83 LC2. Didn't the ones after the LC2 have Allen bolts to hold the pads in where the LC2 has pins held in place with an R clip. Tone.
paulo
Post by paulo on Nov 13, 2011 21:45:39 GMT 1
Yes mate, that a 31K rear caliper, on the later models it was the same style as the front caliper.
nikp
He who dies with the most toys wins
Post by nikp on Nov 13, 2011 21:49:32 GMT 1
Make sure you measure the diameter of the pistons when ordering new ones & seals. There are 2 different sizes fitted to the LC2
Of course I learnt this the hard way and got the bigger ones first and had to replace them with the smaller ones (many thanks as ever to Norbo). Don't know the exact sizes but the bigger ones are about 43mm dia. and the smaller ones are about 38mm dia.
Mine is a late '85 LC2 and has the small ones... which is odd as I would have thought that the later models would have had a bigger dia...?
Post by fatfredfaefife on Nov 14, 2011 10:02:49 GMT 1
Thanks for all the replies, sorted now and will be in touch with Norbo for some seals & pistons.
Post by Tone on Nov 14, 2011 12:17:06 GMT 1
They probably reduced the piston size on the later ones as it is quite easy to lock up the rear wheel as it has two opposed pistons where the fronts are single piston floating type. Thought it was me but on having read some old roadtests everyone comments on the rear brake being too powerful and that they should have stuck with the drum like the early LCs.
Post by woodentopp on Nov 14, 2011 14:34:21 GMT 1
Yep, definately the calipers from the LC2. Mine is an 1983 LC2 that the smaller piston diameter as well 38,5mm.
