Post by Fingermaus on Nov 13, 2011 11:16:54 GMT 1
I have another bit missing where the rad guard mounts. Does anyone have a photo of what this mount looks like please? This is the last jigsaw piece before powder coating Cheers Phil
Post by midlifecrisisrd on Nov 13, 2011 12:02:30 GMT 1
Not got a pic but it's a simple bit of metal about 15mm with a rounded end with an M6 nut welded on the back. It goes straight back to the frame then has a 90 degree bend where it meets the frame to take it to the original weld.
Hope that helps, Steve
Post by Fingermaus on Nov 13, 2011 12:14:15 GMT 1
Brilliant, thanks again Steve.
That chain guard mount is sorted now.I cut the missing bit off the one you sent me, and got it welded on to the existing one in the end.Worked a treat.
Post by midlifecrisisrd on Nov 13, 2011 23:00:07 GMT 1
Brilliant, thanks again Steve. That chain guard mount is sorted now.I cut the missing bit off the one you sent me, and got it welded on to the existing one in the end.Worked a treat. Glad it worked out fine. Steve
