Post by woodentopp on Nov 12, 2011 9:21:05 GMT 1
Does anyone know who sells the rubber mounting bushes for the YPVS that press into the upper engine case. I can't find them in Norbo or Yambits. Thanks in advance for the help
Post by oldelsieboy on Nov 12, 2011 11:58:25 GMT 1
Does anyone know who sells the rubber mounting bushes for the YPVS that press into the upper engine case. I can't find them in Norbo or Yambits. Thanks in advance for the help Have you tried a Yamaha main dealers such as FOWLERS of BRISTOL ? Have the part number to hand otherwise it may be a very long phone call OEB
Post by paul8899 on Nov 12, 2011 15:01:54 GMT 1
I took mine out and really wish I didn't , was only after I did that I saw some on ebay ( only seen one set in a year ) and they were just under a £100 for a new set of 4 ! So I did a bit of googling and found this site www.polymax.co.uk/Anti-Vibration_Rubber_Mounts/Semi_Bonded_Bushes.shtmlI didn't find out how much they were cos I'm tight and made my own ones
Post by onewheelsenough on Nov 12, 2011 16:37:54 GMT 1
i replaced a set. its not an easy job. i drilled the rubber out so i was left with the outer sleeve. used some spacers and threaded bar to pull them out. you have to heat the casings up a bit to expand the alloy. not a job for the faint hearted if you are doing it to a set of matching cases
