Post by thatoldman on Nov 10, 2011 23:10:35 GMT 1
Post by looey on Nov 10, 2011 23:15:33 GMT 1
Hi mate, and welocome Maybe a YPVS top end on a 4L1 bottom end (has been done) Or....... the numbers have been changed/tampered with
Post by thatoldman on Nov 13, 2011 17:03:42 GMT 1
Hi looey, thought of that but the barrels are bolted on in a different way with the LC and ypvs
Post by scott on Nov 13, 2011 20:20:43 GMT 1
vensac on here owns or owned one,lc bottom end with pv barrels grfted on. can only be what looey has already posted.
where does your clutch cable go into the motor,has the top engine case got a small lever just behind the engine number or does it go in the top of the lefthand engine side cover.
Post by Paul Dawkins on Nov 13, 2011 20:33:34 GMT 1
Send me photos of the frame number and engine number and I will tell you if they have been tampered with mate. Engine numbers are very hard to re-stamp email is dating.officer@aircooledrdclub.org.uk
Post by thatoldman on Nov 17, 2011 20:08:39 GMT 1
Hi Guys , Thanks for the reply's, clutch leaver on the top of case just behind engine No. I will send photo's of engine No asap cheers keith
Post by scott on Nov 17, 2011 22:16:57 GMT 1
Hi Guys , Thanks for the reply's, clutch leaver on the top of case just behind engine No. I will send photo's of engine No asap cheers keith thats a pv engine then so can't be matchin numbers,sounds like the numbers have been messed with m8
Post by thatoldman on Nov 18, 2011 21:21:48 GMT 1
Hi Guys picture of engine number *4L1-008157* Attachments:
Post by thatoldman on Nov 18, 2011 21:28:56 GMT 1
this is the best pics , should have seen the rest C**p Attachments:
Post by thatoldman on Nov 18, 2011 21:36:04 GMT 1
Last one of the engine Attachments:
Post by onewheelsenough on Nov 18, 2011 22:57:28 GMT 1
the number looks fairly original the lines look spot on. so one of two think have been done. new old stock engine cases been stamped with a 4l1 number of someone has cut the piece off the lc cases and stuck it on the ypvs cases. the case looks a bit tall where the number is so i think its the last one
Post by scott on Nov 18, 2011 23:25:36 GMT 1
i would agree with onewheel,looks like it's had the number sliced off an lc casing and glued onto the pv cases m8
Post by thatoldman on Nov 19, 2011 9:12:42 GMT 1
Hi Guys thanks for the very prompt replys, so what have I got ? still a problem, why would anyone go to these lenths for a ypvs lump, when so many on the market (EBAY) is full of them!!!!!!!, anyway it goes like shit so unless anyone wants a bitser rd I'll keep it for a while and use it before I change my underware!!!! cheers again
Post by scott on Nov 19, 2011 23:36:59 GMT 1
Hi Guys thanks for the very prompt replys, so what have I got ? still a problem, why would anyone go to these lenths for a ypvs lump, when so many on the market (EBAY) is full of them!!!!!!!, anyway it goes like shit so unless anyone wants a bitser rd I'll keep it for a while and use it before I change my underware!!!! cheers again well i can't see why anyone would got to the trouble of doin it m8 only to get a matchin numbers bike but it's not an lc motor so i'm baffled ???only thing is if anything happens and the insurance dig deep enough it probably won't be insured...looks a nice bike tho lets av some full pic's then..might be an idea to get some legit pv cases and swap all the bits over.
Post by dredge3 on Nov 20, 2011 22:23:05 GMT 1
Didnt we have the same issues about a year ago? sure we did.Possibly the same bike.We decided a few came from factory with ypvs engine.We had spot on pictures and couldnt fault frame or engine numbers.Cant we in anyway trace the numbers to Yams data?
Post by thatoldman on Nov 21, 2011 20:04:56 GMT 1
Hi Dredge3 , thanks for the reply , No not me , but if you can help . I have had the bike for 3years mainly in lots of bits , how do I trace the data , I will enclose a couple of pics now its together Keith
Post by thatoldman on Nov 21, 2011 20:21:22 GMT 1
photo 1 Attachments:
Post by thatoldman on Nov 21, 2011 20:22:39 GMT 1
photo 2 Attachments:
Post by scott on Nov 21, 2011 22:56:55 GMT 1
nice bike so it's worth sortin sommat with it
