Post by gibsonexhausts on Nov 9, 2011 13:31:24 GMT 1
Not too up on the early RD's, been far too many years since I've had any.
Would an early C or D engine go into the E frame? And if so is there anything else that would need changing?
Post by gazzatt2 on Nov 9, 2011 19:58:05 GMT 1
yes
400 engine top rear engine brackets are different to 250 due to rubber mounts easy enough to make some
higgsy
Post by higgsy on Dec 2, 2011 17:03:59 GMT 1
Not coming over to the dark side are you Tony? :-)
Post by Norbo on Dec 2, 2011 19:29:39 GMT 1
well i have a D frame with a 400E engine fitted so it can be done and nothing had to be choped or welden in to make it fit . of course im no A/C expert ether so it could just be a E top end for all i know . But im sure i was tiold the bottom numbers are E as well .
