Post by lcowner on Nov 8, 2011 11:48:49 GMT 1
this is best way ive found to bleed brakes and has always worked for me,hope u find it usefull: u dont need any special tools that never work anyway ,.it also helps if a freind keeps the master cylinder topped up for u. 1st of all u need to get ur self a dosing syringe from ur local vet -get the biggest one u can find (approx 2 euro) a length of clear pipe to fit over the end of the syringe(again approx 1-2 euro) looks like this: do 1 calliper at a time 1-cable tie ur brake lever to the bar 2-fill ur master cylinder(m/c) to the brim with fresh fluid 3-open up the calliper nipple fully until fluid comes flowing out,then close nipple 4-connect clear pipe to the calliper nipple,and open nipple slightly 5- keeping m/c full all the time,start drawing the fluid through the lines into the syringe,you will see lots of bubbles 6-when syringe is full of air + fluid mix, lock the nipple-this will give u a chance to empty the syringe and stop air getting back into system 7-repeat the above until u are happy that all air is drawn from system 8-lock nipple 9-pump brakes and you should feel good 'bite' on the lever 10-top up m/c to recommended level 99% of air will be outa system by now.do other side now and then cable tie the lever over night-this will get rid of the tiny air bubbles left in system and hey presto 1 finger braking!!
