Post by davey on Nov 7, 2011 21:12:15 GMT 1
i just changed the piston and seal on my 250 lc brake calliper and now i cant pump it to any pressure even though fluid and no air is coming out of the nipple albeit slow. i changed the hose too . it actualy worked ok b4 but the piston was a bit knarly which is y i changed it . any ideas.
cheers
Post by onewheelsenough on Nov 7, 2011 23:31:41 GMT 1
sometimes the master cylinder gets air locked. remove the banjo on the cylinder. put you finger over the hole pump it until you get pressure. refit your hose and banjo and try bleeding. you sometimes have to do it a few times
Post by davey on Nov 8, 2011 10:40:11 GMT 1
thanks guys ill try the tips
Post by lcowner on Nov 8, 2011 11:52:26 GMT 1
i just changed the piston and seal on my 250 lc brake calliper and now i cant pump it to any pressure even though fluid and no air is coming out of the nipple albeit slow. i changed the hose too . it actualy worked ok b4 but the piston was a bit knarly which is y i changed it . any ideas. cheers see my 'budget brake bleeding' post
