Post by daglad on Nov 7, 2011 0:23:43 GMT 1
Hi all, this question must have been asked a lot before but how hard/easy is it to get the gear selector shaft bush out and a replacement put in, what is the technique?
Post by nikfubar on Nov 7, 2011 0:34:12 GMT 1
It's easy if the engines apart, just drift the old one out with a socket, I put the new one in the freezer over night & it tapped in easy
Post by JonW on Nov 7, 2011 1:14:18 GMT 1
what he said. I used heat on the cases before drifting it out too.
Post by daglad on Nov 7, 2011 18:35:12 GMT 1
paulo
Post by paulo on Nov 7, 2011 20:50:01 GMT 1
To avoid a full engine strip down, i've heard that some people have knocked the old bush through into the gearbox leaving it on the gearshift shaft. Then just knocked a new one in from the outside. Not sure if they rattle thou, but its one method of replacing without stripping the motor down again !.
Post by rdorvfr on Nov 8, 2011 4:45:32 GMT 1
Thanks for the reminder, I have that longer bush in a packet somewhere. Will place with the necessary parts
Post by nikfubar on Nov 8, 2011 9:43:37 GMT 1
You know when you are putting your cases together and you think there was one last job nagging away in the back ground and you just can't put your finger on it but you carry on regardless........... any thoughts as to how i do it with the cases together? You could try an expanding wrawl bolt & pull it out or cut through it with a junior hacksaw blade & fold it in on itself pain in the arse job though
Post by daglad on Nov 8, 2011 19:54:24 GMT 1
me and stan stevens in the same thread how cool is that, pity we both Fecked up ;D
It's got to be done so i am going to split the cases again oh ye and my washing machine has just chucked its lot across the kitchen floor.
Post by dredge3 on Nov 8, 2011 21:41:15 GMT 1
Get a Bosch washing machine, well worth the extra £ and they can be repaired
