jonniebick
Nice Bike...How fast duz it goo mister????
Post by jonniebick on Nov 6, 2011 16:03:23 GMT 1
I presume most or at least some of you have had your bikes on a Dyno at some point. I took mine yesterday, put it up on the ramp plugged it in and started her up.. The dyno machine couldn't read my revs,, Readings were more than double what they should of been and very erratic. I know that we have a wasted spark but didn't realise these machines couldn't read correct.. Anyone have a solution??? Also on another related matter, I got myself a Koso tacho for my next build, I tried it on my first bike with the same sort of problem as the Dyno.. double the reading.. I know quite a few people use Vapour tacho's, do you get the same problem with these and if so how is it cure??? Can anyone help before I pull the rest of my hair out....
Post by ianboom on Nov 6, 2011 20:34:37 GMT 1
Resistor plugs/caps should help. If the dyno is reading double, it's either picking both plugs up due to the lack of suppresion (no resistor plugs) or hasn't been set up correctly on the dyno. If this is Kev's in Cradley, I reckon your bike is at fault! If you have resistor plugs/caps, then make sure your earths are OK. The KOSO clocks should be setupable for for 1,2 or 4 cyls, is the setting correct??
jonniebick
Post by jonniebick on Nov 6, 2011 23:09:47 GMT 1
No its not Kevs Dyno, its a new one opening up in Cannock.. I did the wiring for it and my run was a tester.. I dont have resister plugs or caps fitted so will give em a go.. Regards the clocks, looks like I need to read the manual....
If all else fails Marty, then I'll call him...
higgsy
Post by higgsy on Nov 8, 2011 0:19:48 GMT 1
That sounds to me that the dyno wasn't set up for wasted spark properly, the lack of resister plugs/caps could cause spikes and glitches in the readout but you should still get a reading.
I always have problems with the TZR trying to get a reading let alone double! Nowhere to put the take off cables. The LC generally goes straight on without any probs.
Sounds just like teething probs with a new dyno to me, sure they'll get it sorted
jonniebick
Post by jonniebick on Nov 9, 2011 21:12:42 GMT 1
Got my Koso working fine now,, Ian was correct, setting the clock up correctly works every time,,, next time I'll read the instructions....
jonniebick
Post by jonniebick on Nov 23, 2011 23:57:32 GMT 1
You are correct.. It is a dyno jet machine, the operator has since read the instructions and now knows how to change the settings... He is having trouble with the cooling fans not delivering enough air flow.. hes now purchased a three phase 11kw fan motor and duct, I reckon he's now gonna have trouble keeping the doors shut!!!!
Post by Deleted on Nov 24, 2011 22:47:07 GMT 1
bleeding hell that fan will be usng 27.5 amps, hope its on its own breaker
jonniebick
Post by jonniebick on Nov 24, 2011 23:40:15 GMT 1
Post by Norbo on Nov 29, 2011 13:44:23 GMT 1
I hope you didnt have to pay for the rin. Have you asked Vin or nickfubber both have experiance with this type of dash .
Post by Deleted on Nov 30, 2011 16:19:46 GMT 1
laughs at muggins here, dont forget to calculate for voltage drop
