375 00
Oct 26, 2011 20:21:44 GMT 1
Post by steven on Oct 26, 2011 20:21:44 GMT 1
Hi, I have a left hand LC carburetor that is marked 375 00 I dont think it is from an LC, as it has not got the 4L1 or 4L0 number on it, any other LC carb iv seen has got the 4L1 or 4L0 number on it. Does anyone have any idea what the 375 00 number denotes please? thanks in advance, Steven.
375 00
Oct 27, 2011 9:34:22 GMT 1
Post by Norbo on Oct 27, 2011 9:34:22 GMT 1
not a clue but if you put up a pictur or 3 of it we may have a better idea . Most likely of some A/C bike i would think.
375 00
Oct 27, 2011 16:06:17 GMT 1
Post by steven on Oct 27, 2011 16:06:17 GMT 1
Hi, Here are some pics of it. the tick over screw looks different to an LC one, so does the float bowl overflow pipe and float bowl drain screw. I can barely make the numbers out, but still recon it is 375-00 Oh and the sight glass for the carb synchronization has been sandblasted, iv never seen that on an LC carb either ! cheers, Steven.
375 00
Oct 27, 2011 16:13:23 GMT 1
Post by midlifecrisisrd on Oct 27, 2011 16:13:23 GMT 1
Are you sure it's not 31k 00
375 00
Oct 27, 2011 18:37:26 GMT 1
Post by steven on Oct 27, 2011 18:37:26 GMT 1
hi, thanks for the reply. i have checked again using a magnifying glass, and i cannot get a posative id on the number. what is stamped on a normal 31k carb ?
375 00
Oct 27, 2011 19:34:08 GMT 1
Post by kennyroberts on Oct 27, 2011 19:34:08 GMT 1
i have some close up shots of my carbs on my posting 350 full nut and bolt rebuild (page 7) they look like mine , but there may be subtle differences, check em out, and ill take a look in the garage for the close up of the code numbers
375 00
Oct 27, 2011 19:45:15 GMT 1
Post by kennyroberts on Oct 27, 2011 19:45:15 GMT 1
mine say UA and underneath say 00 and these are of a uk F2 ypvs, but still check the pics out for comparison, i would link if i knew how
375 00
Oct 27, 2011 19:52:24 GMT 1
Post by midlifecrisisrd on Oct 27, 2011 19:52:24 GMT 1
hi, thanks for the reply. i have checked again using a magnifying glass, and i cannot get a posative id on the number. what is stamped on a normal 31k carb ? 31k ypvs carbs are stamped 31k 00 and german imports are 31L 00 N2 and F2 YPVS powerjet carbs are 1UA 00 for early ones and 1UA on later ones. 350R is 4CE 00 That's all I've seen so not a definative list. Steve
375 00
Oct 29, 2011 16:53:36 GMT 1
Post by steven on Oct 29, 2011 16:53:36 GMT 1
hi, thanks for the reply,s i have had a look at the carbs on your page 7, and they do look like the one i have. i recon it must be a YPVS carb and not an AC carb as i origonaly thought. I still cant decide what the number is, today I think it looks like 41K 00.......was there a 41k 00 YPVS ? steven.
375 00
Oct 29, 2011 20:36:23 GMT 1
Post by oldelsieboy on Oct 29, 2011 20:36:23 GMT 1
i recon it must be a YPVS carb and not an AC carb as i origonaly thought. I'm no expert but arent AC carbs 28mm not 26 OEB
375 00
Oct 29, 2011 20:44:46 GMT 1
Post by gazzatt2 on Oct 29, 2011 20:44:46 GMT 1
i recon it must be a YPVS carb and not an AC carb as i origonaly thought. I'm no expert but arent AC carbs 28mm not 26 OEB yes AC carbs are 28mm
375 00
Oct 31, 2011 13:05:28 GMT 1
Post by Norbo on Oct 31, 2011 13:05:28 GMT 1
I bet its 31K looks like a 26mm carb and looks very ypvs to me . Does the non carb have a brass tube coming from the midle of it ./
Look on the lc history page to see what i talking about on the main site
375 00
Oct 31, 2011 14:08:51 GMT 1
Post by wozzap on Oct 31, 2011 14:08:51 GMT 1
31k carbs have black slides, if that helps
375 00
Oct 31, 2011 17:46:48 GMT 1
Post by midlifecrisisrd on Oct 31, 2011 17:46:48 GMT 1
31k carbs have black slides, if that helps Not all of them, my last set had gold slides, not sure which was earlier/later Steve
