Post by brian1111 on Oct 19, 2011 19:58:21 GMT 1
hi all got a few things i want to no got a rgv front end to put in my 250lc does anyone no the part number for the headstock bearings i have a vj22 back wheel the back brake i got with it has a bracket on it which i think the spindle goes through and torque arm fastens to but didnt get a spindle or spacer with the wheel could any1 tell me if it has a spacer both sides and if so can any1 give me the measurements of the spacers and can any1 tell me how to upload more than 1 picture has i tried to on my 1st post and could only get 1 on would like to post pictures of the progress of it and the start pictures many thanks bri Attachments:
Post by soccersmyth on Oct 19, 2011 21:36:16 GMT 1
Open up a photobucket account and put your pictures on there. Then copy and paste them into your posts here. Assuming it's RGV USD FORKS AND same year swingarm, there's a spacer between the arm and the sprocket carrier. Another spacer inside the sprocket carrier and the brake caliper carrier acts as the spacer on the other side. The rear wheel spindle off a GSXR400(GK76A) is the same as the RGV one, so this should help in your search. Norbo, our worshipfull master(on here) does the headstock bearing you need. Here's a link to his online shop. homepage.ntlworld.com/ultimatelccrazy/Fill you're boots and good luck. Don't be afraid to ask Q's. We'll help when we can.
Post by JonW on Oct 19, 2011 21:37:23 GMT 1
Love that pic! What a find! Do you have a high res version? Just get normal LC bearing and a spacer from Norbo for the front. If you want more info on RGV front and rear ends then check my 421 build and also NikFubars post in the technical section, those should help. For RGV parts layout, check an online parts fiche pic, simples
Post by ngordoncrosby on Oct 21, 2011 6:26:21 GMT 1
How long has that bike been sitting for?
Post by dredge3 on Oct 22, 2011 20:24:02 GMT 1
still cant beleive people find classic bikes in old barns, back garages etc
