shugsi
Post by shugsi on Oct 13, 2011 19:51:54 GMT 1
Hi guys needing some questions answered.... 1: Will F2 footrest hangers fit onto the 31K/N1 frame? 2: Will the F2 exhausts fit as normal using the F2 footrests for mounting? (running a F2 engine in 31K chassis) 3: Is there a difference in the F2 handle bar switches and the 31K ones? 4: Any other shocks in the Yamaha range that will replace the standard item? 5: Can the F2 rear swing arm, dog legs be fitted into the 31K frame? 6: Has anyone used 28mm Keihin PWK carbs on their Ypvs bikes? ;D
Post by Shytalk on Oct 13, 2011 20:21:24 GMT 1
Hi guys needing some questions answered.... 1: Will F2 footrest hangers fit onto the 31K/N1 frame? YES2: Will the F2 exhausts fit as normal using the F2 footrests for mounting? (running a F2 engine in 31K chassis) YES3: Is there a difference in the F2 handle bar switches and the 31K ones? YES4: Any other shocks in the Yamaha range that will replace the standard item? YES early FZS600 does but needs bottom mout swapping5: Can the F2 rear swing arm, dog legs be fitted into the 31K frame? YES later 31K has the same arm anyway6: Has anyone used 28mm Keihin PWK carbs on their Ypvs bikes? ;D
shugsi
Post by shugsi on Oct 13, 2011 20:32:54 GMT 1
Hi guys needing some questions answered.... 1: Will F2 footrest hangers fit onto the 31K/N1 frame? YES2: Will the F2 exhausts fit as normal using the F2 footrests for mounting? (running a F2 engine in 31K chassis) YES3: Is there a difference in the F2 handle bar switches and the 31K ones? YES4: Any other shocks in the Yamaha range that will replace the standard item? YES early FZS600 does but needs bottom mout swapping5: Can the F2 rear swing arm, dog legs be fitted into the 31K frame? YES later 31K has the same arm anyway6: Has anyone used 28mm Keihin PWK carbs on their Ypvs bikes? ;D Hi Shytalk, thanks for reply.....is swapping out the bottom mount on the Fzs600 shock a DIY job?
Post by Shytalk on Oct 13, 2011 20:41:01 GMT 1
Shock bottom is do-able using a vice to clamp the shaft then unscrewing the bracket, just need to take care when clamping the shaft so as not to damage the chrome.
