Post by alext on Oct 13, 2011 13:44:14 GMT 1
Anyone knwo where to get a replacement plug for the alternator to loom connection?
its the 4-way plug with 3 white and one blue wires.
plus... and importantly.......
Does it matter which of the white wires connects to which on the plug?
Ta
Alex.
Post by lcowner on Oct 13, 2011 14:08:41 GMT 1
norbo will sort the plug and it doesent matter where the white wires go mate
Post by mellow on Oct 13, 2011 16:06:38 GMT 1
Post by scott on Oct 13, 2011 22:29:14 GMT 1
is it the one on the alternater or on the loom?i might have a scrap loom with it on but not 100% sure m8.
Post by kennyroberts on Oct 13, 2011 22:42:20 GMT 1
how bizzar is that, i have just been trying to strip mine an hour or so ago ,and was marking up these 3 white and 1 blue wire,
but how the hell do i get the block off! and the one with the three wires? (long flat one) i have done loads of block removals from other parts of the loom, but these round B*#~t^-ds dont wanna budge !
Post by scott on Oct 13, 2011 22:46:13 GMT 1
which bikes its for m8?
Post by nikfubar on Oct 13, 2011 22:49:57 GMT 1
how bizzar is that, i have just been trying to strip mine an hour or so ago ,and was marking up these 3 white and 1 blue wire, but how the hell do i get the block off! and the one with the three wires? (long flat one) i have done loads of block removals from other parts of the loom, but these round B*#~t^-ds dont wanna budge ! These are real b*****ds to get out check out these, they are the same pins & you can see the two little tags that stick out, you have to push these in with a tiny screwdriver www.ebay.co.uk/itm/MOLEX-connector-set-Standard-093-2-way-2-circuit-/120688316353?pt=UK_Motorcycle_Parts&hash=item1c19958fc1I'm just fitting my loom as well
