Post by gerumgoin on Oct 11, 2011 21:54:07 GMT 1
Hi all,so I've got a few different exhausts i picked up for my rd125lc that i'm rebuilding,do you ever feel the need to De-coke them if so what method do you use?
Post by kennyroberts on Oct 11, 2011 22:12:32 GMT 1
couple of options, petrol shifts it,soak them in it for a day or so ....... but the hazards and pitfalls are obvious ! dont blow yerself up!
or caustic soda crystals , make up a solution and soak . this takes much longer, but does work well !
both can be done by bunging up one end and filling the pipes up , good luck
Post by kennyroberts on Oct 11, 2011 22:13:37 GMT 1
Post by mellow on Oct 12, 2011 16:51:35 GMT 1
i used caustic soda mix on my 125 standard pipe.mixed up at the correct ratio,left overnight and the next day emptied out a lovely brownish mix with a few black bits mixed in.
Post by gerumgoin on Oct 12, 2011 19:37:22 GMT 1
Thanks all,ill give the caustic soda ago first. ;D
Post by rdorvfr on Oct 23, 2011 3:47:48 GMT 1
How'd you go with the decoke of your exhausts??
Post by Deleted on Oct 23, 2011 8:39:51 GMT 1
well ive only just finished doing one that should scrub up ok, i used petrol, (unleaded naturally) only cause i had a heap of it in soft drink bottles after draining my tank, i put it in and let it sit, then tipped it out,then put it back in and flushed it all about, a few times, its jet black, the spent fuel that is, i think it should be fairly clean in side,sand blasted it today aswell and it didnt blow up, once i was sandblasting in a fairly dark enviroment and occasionally sparks would fly while blasting.
