Post by Dieseldog on Oct 8, 2011 22:51:48 GMT 1
Is it possible to replace the 'window' on the carb? Had them vapour blasted now can hardly see the slide through them If so where can you get the window from?
Post by kennyroberts on Oct 8, 2011 23:14:47 GMT 1
i have just done the same, and a bit of clear laquer on them helps a LOT
Post by wiseric on Oct 10, 2011 0:54:04 GMT 1
I know it's too late now but next time use a bit off silicone to protect the windows. that's what I used and it worked a treat. Try speaking to a watch maker, i'm sure they can recommend something for removing scratches from glass.
Post by twostroker on Oct 10, 2011 18:18:04 GMT 1
you can flat and polish glass the same way as you would to car paint work.ive done a few car lights and windows that were scratched up,obviously glass is much harder than paint so its time consuming but it is possable. with the glass windows on the carbs i would put a put of p1200 round a match stick or tube from a cotton but and try flat out the etching marks,them 2000 wet and dry and then some g3 on a cotton or similar but but it will be time consuming fot little end result,depends how fussy/bothered you are.
Post by ivymike on Oct 10, 2011 19:56:29 GMT 1
jewellers use a compond called jewellers rouge . i think thats how its spelt.
Post by aaron on Oct 10, 2011 22:32:53 GMT 1
Post by Dieseldog on Oct 11, 2011 12:50:39 GMT 1
then some g3 on a cotton or similar but but it will be time consuming fot little end result,depends how fussy/bothered you are. Take it g3 is some sort of polishing compound? Just want to be able to see the drill marks on the slides
Post by Dieseldog on Oct 11, 2011 12:52:41 GMT 1
Looks like polishing rather than replacing then Cheers for the replies.
Post by twostroker on Oct 11, 2011 18:29:22 GMT 1
Looks like polishing rather than replacing then Cheers for the replies. yes g3 is a medium grade compound made by ferecla.any compound will do with in reason.to save buying any id try t-cut,autosol or even glass polish as its only a tiny area. sorry i should have been clearer
