Post by Fingermaus on Oct 7, 2011 19:57:34 GMT 1
I'm about to get the swingarm powder coated,and a small repair is needed on the front chainguard mount.Its missing and a new one needs to be made and welded on Could anybody help out with a couple of measurements please? I need the horizontal measurement from the swingarm to the outer edge of the mount, and the vertical measurement from the bottom of the mount to the bottom of the mount threads. Cheers Phil
Post by midlifecrisisrd on Oct 7, 2011 20:22:20 GMT 1
Does the guard not locate on to the other mount at the front which should make it easy to work out.
Sure I have a good arm buried in the garage that just needs paint that you can have for the cost of post.
Up to you, Steve
Post by Fingermaus on Oct 7, 2011 22:31:37 GMT 1
It does locate,but I wanted to make sure just in case the inner locating mount is a bit out. But if you can dig that other one out that would be mint.
Post by midlifecrisisrd on Oct 8, 2011 11:03:47 GMT 1
It does locate,but I wanted to make sure just in case the inner locating mount is a bit out. But if you can dig that other one out that would be mint. I'll dig it out and check it is good. Pm me your address and I'll let you know how much it cost, will send cheapest royal mail option. Steve
Post by Fingermaus on Oct 8, 2011 15:12:19 GMT 1
PM'd, thanks for this Steve.
Have a chunk of Karma.
