Post by lcowner on Oct 6, 2011 23:43:41 GMT 1
is there any available 4 a 4lo?n if not y not???
Post by midlifecrisisrd on Oct 7, 2011 8:43:12 GMT 1
Never heard of anything for the 4L0
Probably as the YPVS stuff started from the banshee ATV's and now being used on the bikes.
All you could do was get someone to cut it with a better shape/volume.
Post by lcowner on Oct 7, 2011 8:51:14 GMT 1
Never heard of anything for the 4L0 Probably as the YPVS stuff started from the banshee ATV's and now being used on the bikes. All you could do was get someone to cut it with a better shape/volume. Steve thanx steve wud it be possible to get it machined up with the inside being 'hollow'?maybe in 2 parts but wouldent it be very messy ect? paul
Post by midlifecrisisrd on Oct 7, 2011 20:00:05 GMT 1
Not got any experience of the 4L0 stuff.
Most people just through a valve engine in.
Either that or use a valve bottom end with lc covers with an athena non pv top end if you want it to look lc.
Post by tobster on Oct 14, 2011 10:09:49 GMT 1
does the PV engine just drop straight in, especially if it has PWK28 carbs fitted? What about the exhaust pipes. Would F2 pipes fit on?
Post by tobster on Oct 14, 2011 15:34:58 GMT 1
thanks Headcoat. Now i have your attention, what's the best way to get 17" wheels/tyres fitted?
