Post by lcowner on Oct 4, 2011 12:25:55 GMT 1
right my 4lo fuel tap is leaking through the outlets when its in the off position,what would be wrong with it?i have replaced the o ring on the end of the tap itself but its still leaking i know norbo does the repair kits but i have replaced the o ring so what else could it be can the white plastic thingy wer the tap turns inside it be replaced??
Post by lcowner on Oct 4, 2011 14:51:45 GMT 1
well come on whats the answer-a new tap?
Post by rdorvfr on Oct 5, 2011 10:53:24 GMT 1
my only input is the holes for closed arent line up. Ive done that before whilst changing the O ring. When I spun it round and changed the O ring, leak stopped. Sorry, that's all I got
Post by lcowner on Oct 5, 2011 12:50:32 GMT 1
mmm i'l check dat never thoro that
Post by nikfubar on Oct 5, 2011 22:55:12 GMT 1
Whals't we're on the subject, has anyone got an exploded view of these fuel taps got one to fit on my latest build but not sure it's all there
Post by lcowner on Oct 6, 2011 1:20:10 GMT 1
Whals't we're on the subject, has anyone got an exploded view of these fuel taps got one to fit on my latest build but not sure it's all there page 41 here www.skills.plus.com/manuals/RD350LC.pdf
Post by nikfubar on Oct 6, 2011 18:20:01 GMT 1
Yeah cheers, I've seen that one before but it does'nt show what's inside the tap, ie the cone shaped plastic bit & is there another O ring as the repair kits have 3. On my tap I think the springs broken off as it doesn't protrude past the end of the tap by much plus I only have one O ring in the thumb turn bit & it all seems very sloppy Just realised is the 3rd O ring the 'gasket' for connecting it to the tank
Post by lcowner on Oct 6, 2011 20:22:47 GMT 1
3 orings nik 1 for under the tank, 1 for the bowl and 1 for the thumb bit ,im still trying to find out does the plasic bit inside come out? ?
neil
my 125
Post by neil on Oct 9, 2011 22:31:52 GMT 1
i have a tz tap on my 125. only had it about 6 months and it floods the carb over night. i wonder if this crap fuel is playing the seals up
Post by rdorvfr on Oct 26, 2011 12:04:18 GMT 1
3 orings nik 1 for under the tank, 1 for the bowl and 1 for the thumb bit ,im still trying to find out does the plasic bit inside come out? ? Yep, it should come out. Dropped mine out on the weekend. Used a big flat screwdriver to turn it and let gravity do its thing. May need a bit of WD40 (called lizard piss in our neck of the woods) . Good Luck
