stuboy
Post by stuboy on Oct 2, 2011 21:18:29 GMT 1
What 4 pot calipers fit the RDLC ?
Post by oldelsieboy on Oct 2, 2011 21:40:49 GMT 1
What 4 pot calipers fit the RDLC ? 4L0, none without adaptor brackets OEB
Post by Norbo on Oct 3, 2011 0:15:14 GMT 1
as above but NK racing is who i use for all my caliper brackets . then you can fit what ever you like as he will just make a beacket to fit it
stuboy
Post by stuboy on Oct 3, 2011 11:49:33 GMT 1
Would twin R1 brakes be too good for the elsie causing the front to keep washing out or the forks to bend under braking too much ?
paulo
Post by paulo on Oct 3, 2011 13:55:47 GMT 1
Hi mate, Harrison Billet do 4 pot replacements that bolt straight on, so no need for adapter brackets. Slightly expensive, but Santa's only around the corner, I'm eating all by green's and putting the toilet sit down, so you never know ;D.
Post by lcowner on Oct 3, 2011 13:58:27 GMT 1
i hae them on mine and its 1 finger braking ,there awsome
Post by johnlc on Oct 3, 2011 14:00:04 GMT 1
Hi mate, Harrison Billet do 4 pot replacements that bolt straight on, so no need for adapter brackets. Slightly expensive, but Santa's only around the corner, I'm eating all by green's and putting the toilet sit down, so you never know ;D. Have them on my own lc and they are awesome but expensive as their is 4 of everything
Post by lcowner on Oct 3, 2011 14:21:22 GMT 1
Post by oldelsieboy on Oct 3, 2011 17:18:04 GMT 1
Harrison Billet do 4 pot replacements that bolt straight on, so no need for adapter brackets. Slightly expensive Ah yes, forgot about those & at £500 a pair I wonder why OEB
Post by oldelsieboy on Oct 3, 2011 17:19:03 GMT 1
I just bought a pair of those for a lot less than that ;D OEB
Post by Norbo on Oct 4, 2011 11:31:04 GMT 1
Post by johnlc on Oct 4, 2011 12:12:31 GMT 1
go onto Ap's website they are still doing them
Post by oldelsieboy on Oct 4, 2011 21:17:01 GMT 1
go onto Ap's website they are still doing them The calipers are still available new at about £120 each OEB
Post by rdorvfr on Oct 5, 2011 11:02:01 GMT 1
Sorry to Threadjack, I checked out these calipers and ended up on a website called vintagebrake.com There was an article describing the ratio between master cylinder to wheel cylinder. I couldnt work out the ratios, perhaps someone can enlighten us here.
Post by lcowner on Oct 5, 2011 14:55:14 GMT 1
Sorry to Threadjack, I checked out these calipers and ended up on a website called vintagebrake.com There was an article describing the ratio between master cylinder to wheel cylinder. I couldnt work out the ratios, perhaps someone can enlighten us here. which callipers ?i used the blue spot r1 ones and it worked fine with the std lc mastercylinder
Post by rdorvfr on Oct 6, 2011 10:27:01 GMT 1
Sorry to Threadjack, I checked out these calipers and ended up on a website called vintagebrake.com There was an article describing the ratio between master cylinder to wheel cylinder. I couldnt work out the ratios, perhaps someone can enlighten us here. which callipers ?i used the blue spot r1 ones and it worked fine with the std lc mastercylinder The Lockheed ones. I started scrolling around the web and found a site called vintagebike.
Post by Deleted on Oct 6, 2011 13:45:07 GMT 1
i sometimes get a bit confused every now and then,,, if you arent happy with a 30 year old bikes ways, why would you spend a fortune on making an attempt to make it compete with bikes of today? why not appreciate it for what it is and be content with a good example of an old bike?
stuboy
Post by stuboy on Oct 6, 2011 14:05:46 GMT 1
I agree on some fronts as the only thing I will change is the brakes and rear shock. An Elsie may be old but tweeked she is still as fast as most bike to a ton and what with all the idiots on the road good brakes are a MUST !!
Post by Deleted on Oct 7, 2011 3:15:21 GMT 1
fair enough, im i hoping the new genuine yamaha mastercylinder,caliper kits,thanks norbo and stainless lines and new pads will be good enough,or at least be passable, ive said it before but 100mph is no good to me as i need my licence and the cops are everywhere, i like to get from 0 to the speed limit as quick as i can especially if there arent any cars infront of me,probably why i like stop light a bit so i can get to the front,probably safer being behind the clump of cars in the front and the clump you left behind at the lights,a bit off topic, sorry. see ya
