Post by trev1340 on Sept 29, 2011 21:35:59 GMT 1
I need some help my air box and rear mudguard have gone a bit manky airbox has some white patches on it any idea what i can do to spruce them up ie can i paint them if so what sort of paint should i use any help would be gratefully appreciated
Post by Norbo on Sept 29, 2011 21:50:54 GMT 1
you can use some of that back to black stuff may be . If your gowing to spray it allways comes of and starts to look crappy . some times you can spray then wipe over with a cloth so its so thin it wont flake and that can work and give a better black back .
Post by trev1340 on Sept 30, 2011 11:32:20 GMT 1
Cheers will give that a go
Post by Norbo on Sept 30, 2011 13:11:42 GMT 1
But wipe it over first are better still wash it with hot soapy water remember and grese will not go well with any paint .
Post by mellow on Sept 30, 2011 20:27:17 GMT 1
i give my black plastics a degrease,then wash then i use auto glym vinyl/rubber restorer (yellow labeled bottle) then soak the item with it and leave it for a day or so.then buff up with a duster.usually works first time but a second application may be needed
Post by scott on Sept 30, 2011 20:39:09 GMT 1
i can highly recomend the autoglym back to black stuff.the 1 i've got is a green gel.
Post by mellow on Sept 30, 2011 20:49:35 GMT 1
thats the bumper restorer m8
Post by trev1340 on Oct 1, 2011 15:49:50 GMT 1
Cheers for the advice will get on it asap ;D
Post by scott on Oct 1, 2011 22:11:10 GMT 1
thats the bumper restorer m8 ain't got no bumpers on me bike m8
Post by kennyroberts on Oct 1, 2011 22:20:20 GMT 1
i did mine with fine wet and dry all over, after a degrease, sounds harsh, but it gets rid of any faded surface areas, and smooths out any scrapes and gouges, then a fine spray of clear laquer, its how i did this side panel , and my air box etc
Post by scott on Oct 1, 2011 22:26:24 GMT 1
i know this sounds bad but i have used nitromous in the past if the "black" item has deep scratches,wipe off with fine wire wool and wash off then use kennyroberts method with very fine wet and dry then a cuttin paste and finely baxck to black stuff.
