Post by lcowner on Sept 29, 2011 20:33:54 GMT 1
have stripped an m6 thread in my kickstart boss ,if i get an m6 helicoil of evil bay what size hole do i need to drill to accept the helicoil tap?theres only about 5mm of thread in it(very little i know : so will it work ok do you think?thanx in advance guys
Post by Norbo on Sept 29, 2011 21:02:41 GMT 1
if you get a coil thats for a M6 bolt then i think it will be fine if you put it in a m8 holl as they have about a 1mm walll . but id ask the bloke selling it as he will be the one who will know .
Post by lcowner on Sept 29, 2011 21:07:07 GMT 1
Post by billbott on Sept 29, 2011 21:14:53 GMT 1
The drill size will be stated on the helicoil tap. All the info you'll ever need is here: www.helicoil.in/pdf/HeliCoil%20Catalogue.pdfWorth noting too, is that helicoil minimum length is 1D (M6 would be 6mm long) so a 5mm deep hole would be too shallow.
Post by lcowner on Sept 29, 2011 21:18:47 GMT 1
right,,,,,,,,,itsays its 8mm long but can i not cut off excess sticking out?
Post by lcowner on Sept 29, 2011 21:21:36 GMT 1
no mate its oned of those trick alloy kickers
Post by lcowner on Sept 29, 2011 21:30:34 GMT 1
did that mate hes looking £75 for the boss only and it cud do the same imho .............he said try a helicoil first , i cant even bodge it and put a bolt right thru it or nout,shit creek without a paddle comes to mind
Post by nikfubar on Sept 30, 2011 8:26:31 GMT 1
Post by oldelsieboy on Sept 30, 2011 8:44:12 GMT 1
I would have thought the boss would have been made from stainless or something stronger because of the splines If I had recently spend nearly a ton on a specialised machined part & it failed I would be doing everything possible to have the part replaced by the manufacturer, surely it is still under warranty Just my 2p worth OEB
Post by lcowner on Sept 30, 2011 9:46:23 GMT 1
yes i feel the same oeb but as i said hes looking £75+post for the boss alone!!!nik theres very little options i cant drill the hole any deeper or it will be thru the other side and if i do this the kickstart will hit.so i cant even bodge it and put a bolt right thru it..............have orderd a helicoil kit but i doubt ts gunna work as theres so little thread to work with but ive gotta try summit,failing that i'l have to see about a different boss like the original where its a bit more robust of a unit.
Post by midlifecrisisrd on Sept 30, 2011 10:07:31 GMT 1
Got one of these myself and musyt only grip by 3 or 4 mm so easily overtightened and stripped.
Not sure how to sort it but nothing is going to be easy as bolt goes in through bottom into blind end that can't really be drilled any deeper.
The tap for the helicoil will not thread it to the bottom so insert won't go in.
Post by lcowner on Sept 30, 2011 10:41:44 GMT 1
yep thought of that too about the tap!is there any other boss that would fit steve do u know?if all else fails i'l have to weld up the hole maybe and redrill n tap/get a new boss made up but i know its gunna be expensive........even if i was to shell out for a new one the same cud easily happen,£75 is just taking the piss when the whole thing cost £100
Post by oldelsieboy on Sept 30, 2011 11:06:35 GMT 1
Got one of these myself and musyt only grip by 3 or 4 mm so easily overtightened and stripped. Sounds like a design fault. Paul, how long have you kicker? OEB
Post by lcowner on Sept 30, 2011 11:14:44 GMT 1
i have it a while 12 months maybe bought it off 'looey' on here dont think he had it long.think he fitted it to the bike and dident ike the look of it .so i bought it from him.it fitted fine to my bike the trouble started when i tryed to kick over a seized motor a few monhs back but yeah have to agree with ya nigel sh1t design on the boss part.........
Post by lcowner on Sept 30, 2011 11:18:51 GMT 1
im gunna see if i can salvage my kicker so gunna try using the standard 4lo boss can someone tell me that diameter the bit is that the kicker part slides onto the boss is?(the round bit!).i kow i ight have to get a sleeve made up ,hit n miss this but worth a go i think
Post by oldelsieboy on Sept 30, 2011 11:35:17 GMT 1
i have it a while 12 months maybe bought it off 'looey' on here dont think he had it long.think he fitted it to the bike and dident ike the look of it .so i bought it from him.it fitted fine to my bike the trouble started when i tryed to kick over a seized motor a few monhs back but yeah have to agree with ya nigel sh1t design on the boss part......... Ah, didnt realise you bought it off another forum member, thought it came direct from the manufacturer. OEB
Post by lcowner on Sept 30, 2011 17:05:08 GMT 1
i have it a while 12 months maybe bought it off 'looey' on here dont think he had it long.think he fitted it to the bike and dident ike the look of it .so i bought it from him.it fitted fine to my bike the trouble started when i tryed to kick over a seized motor a few monhs back but yeah have to agree with ya nigel sh1t design on the boss part......... Ah, didnt realise you bought it off another forum member, thought it came direct from the manufacturer. OEB no worries nigel
Post by lcowner on Oct 1, 2011 18:42:08 GMT 1
right helicoil dident work there just not enuf thread as i cant get far enough im thinking of getting a 4lo boss and doing a cut n shut on the 2 bosses to make 1- this is turning into a real f**kin nightmare,sorry now i bought the f**kin thing
Post by Deleted on Oct 2, 2011 0:57:57 GMT 1
sorry to hear of your problem, when the last one of those fancy kickstarters from ledgion motorcycles came on ebay for sale ,i thought i had to have one, thought id get it cheap and bid around 80 odd pounds, but from memory it went for 165 or near to it,glad i didnt get it now, i hope you can get yours sorted out,good luck
