Post by stanlc7189 on Sept 28, 2011 23:27:53 GMT 1
Hi fellow LCers
Can anyone recommend the best method for a plug chop? Should it be full throttle under load then cut the engine dead? Sounds a bit brutal to me and I've only just got 300 miles up since it's rebuild. Don't want to thrape it just yet but equally want to make sure carburration is spot on.
cheers
Post by Norbo on Sept 29, 2011 9:08:16 GMT 1
You can take it up to the revs you are happy with then kill it and wip the plugs out and see what colour they are . The idea of doing it full thraps is so when you are rinding it that way you know its running a good mixture .
It may be fine in mid but running week at full throttle flat out if you see what i meen .
But as you wont be flat out you will be fine just to do as above and only take it up to what ever your hapy with.
Post by stanlc7189 on Sept 29, 2011 16:32:50 GMT 1
cheers for that, Norbo. I'll do just that.
