Post by rdorvfr on Sept 28, 2011 13:20:16 GMT 1
Hi, Im in the process of separating my 1981 250LC into as many parts as possible Does anyone have the numbers for the 4 crankcase bearings. I know that one is 83406E (the one with the locating groove) Are the remaining 3 the same bearings ie right hand and two centre bearings (they all have the locating ring instead of groove) The bearing places dont recognise Yam part numbers, just bearing numbers. Im trying to source them locally, if I can. Many thanks
Post by Norbo on Sept 29, 2011 8:55:46 GMT 1
all the bearings are the same but 1 has the locating groove and all 3 have the pins in the correct place so they line up with cut out for it to locate in the casings . I can tell you that any bearing you get wil just be a plane bearing they wont have the groove or the locating pip .
Post by rdorvfr on Sept 29, 2011 23:23:23 GMT 1
Thanks Norbo, yeah I was concerned about that.
Post by Norbo on Sept 30, 2011 13:04:43 GMT 1
if you need as et i have them but post would be like £10 as they are not light .
I may have a number of a person in OZ that can suply you . well an email addess anyway
Post by midlifecrisisrd on Sept 30, 2011 16:27:21 GMT 1
Hi, Im in the process of separating my 1981 250LC into as many parts as possible Does anyone have the numbers for the 4 crankcase bearings. I know that one is 83406E (the one with the locating groove) Are the remaining 3 the same bearings ie right hand and two centre bearings (they all have the locating ring instead of groove) The bearing places dont recognise Yam part numbers, just bearing numbers. Im trying to source them locally, if I can. Many thanks Have you tried the two stroke shop over there, just got my stroked crank from them. Admittedly no locating pegs but do have the grooves. Centre ones have o rings in them which I take it locates them to stop them spinning. Steve
