Post by davey on Sept 20, 2011 7:31:09 GMT 1
hi guys, a little tip here i found last week when fitting the new steering taper bearings to my bike , the top was fairly easy but the bottom was slighly harder. What i did was put the bearing run in the freezer for half an hour then positioned it in the frame a couple of light taps to position it then i used the old bearing run as a protecter to drift the new one home into it position as it is exactly the right size and it saves damaging the new surface . im sure some of you guys knew this but thought i would post it anyway.
Dave
Post by Norbo on Sept 20, 2011 9:28:38 GMT 1
Its a good tip and worth a menshon . thanks .
Post by nige on Sept 23, 2011 18:45:05 GMT 1
did the same with my main bearings but also put the crank cases in oven {mrs was well impressed} but slipped in nice.
Post by davey on Sept 25, 2011 4:22:32 GMT 1
yeah i was thinking the same only the frame wouldnt fit,,, thinking i need a bigger oven
Post by rdorvfr on Oct 17, 2011 4:37:12 GMT 1
yeah i was thinking the same only the frame wouldnt fit,,, thinking i need a bigger oven HaHa frign good one.
