Post by ngordoncrosby on Sept 17, 2011 10:29:27 GMT 1
I had torqued the head down to 17 as it said in the haynes manual but noticed a small bead of water coming out of the join once the engine got up to temp ,so had to tighten up the head a little more is that usual ?
Post by mellow on Sept 17, 2011 11:12:20 GMT 1
it has happened to a few people m8 was it a genuine yam gasket you need to let the engine cool before re tourqing them. Some people also use a tiny amount of sealer on the gasket too Mine leaked in the centre of head so i used the sealer method
Post by Tone on Sept 17, 2011 11:27:16 GMT 1
Did you follow the numbered sequence marked on the head ?
Post by ngordoncrosby on Sept 17, 2011 20:32:56 GMT 1
Yes sure did 1-8 tighten,Ihave also now put a small smear of sealant on there and has seemed to fix the problem,but I think 17lb per haynes manual is a little light !!
Post by Tone on Sept 18, 2011 10:09:14 GMT 1
In the Genuine Yamaha Workshop manual it says :
Cylinder Head Insall new cylinder head gasket and cylinder head. Note: The cylinder head bolts should be tightened in the order of numbers and in two steps. Caution: After installing the engine to frame completely,start the engine, and raise the temperature gauge up to 60 degrees C (86 degrees F). Let the engine cool down and retighten the cylinder head bolts to specification. Cylinder head tightening torque: 24Nm (17 ft-lb)
Hope this helps. Tone
Post by lcowner on Sept 18, 2011 10:28:10 GMT 1
it says 17 but i thought it was a little light myself and have always torqued to 19
Post by ngordoncrosby on Sept 19, 2011 3:56:30 GMT 1
Yer I went to 20 and that seems to have fixed it,plus a little sealant,
Post by stanlc7189 on Sept 21, 2011 23:19:33 GMT 1
I had exactly the same problem as you at 17 ft lb and it was still leaking after a re-torque to 19 ft lb. My solution? - I bought a genuine Yam gasket. It cost £62.50!!! Ouch!! Fixed the problem though and no leaks at the correct 17 ft lb.
Post by airbraker on Oct 4, 2011 2:42:43 GMT 1
Mine leaked from the center. Took it off put a smear of high temp silicon sealer on and put it back on. Ran it let it cool down and torqued it up to about 20 ft lbs and its been fine.
Post by lcowner on Oct 4, 2011 6:12:28 GMT 1
pattern gaskets defo need sealent and torqued to at least 20,ade this mistake i think 3 times now at this stage
Post by Norbo on Oct 4, 2011 12:31:34 GMT 1
i agree allways use instent with patten headgaskets . Ouch £65 stan my gen yam ones are £35 . I have to say i have allways used patten ons my self with no problem but with instent and down to 20 as well . and use clear not that red or blue shite .
Post by lcowner on Oct 4, 2011 14:50:40 GMT 1
thanx for telling us norbs i used that red shite but ya cant see it unlike other times i put it on it was like a dog had spewed his dinner up!!£65 for a head gasket did ya get the barrells and head with that?
Post by ngordoncrosby on Oct 4, 2011 22:16:38 GMT 1
Mine was black shit but it seems to have done the trick,and it was more the fact that I was tightning up the head a little more, but I think that it as minimal really.Now just got to get on to the other 110 problems I have got.
Post by stanlc7189 on Oct 5, 2011 23:33:21 GMT 1
Norbo.....I think I've been done on the gen Yam gasket!!! Do you have a stock of gen Yam ones? I won't be going to Granby again!
Post by Norbo on Oct 6, 2011 9:00:38 GMT 1
yes mate i do keep them in . i woulnt worry about it mate they didnt do you they just charged the normal yam price for it thats all . But you have it now and you can reuse it
Post by mellow on Oct 6, 2011 16:58:42 GMT 1
CAN I RE USE MY YPVS ONE THEN
