Post by critter on Sept 15, 2011 15:38:15 GMT 1
Ive lost all drive to the back wheel on my YPVS.... I can move the gear lever but just get a box of Neutrals... The clutch lever seems to be working the clutch ok.... The front sprocket is still attached.... What do you think could be the cause? What would you check first before i strip engine? Thanks for your help......
lcolin
Post by lcolin on Sept 15, 2011 19:23:11 GMT 1
That the chain is still attached?!!
(sorry probably wanted more constructive advice than that didn't you.) ;-)
Post by critter on Sept 15, 2011 19:36:30 GMT 1
That the chain is still attached?!! (sorry probably wanted more constructive advice than that didn't you.) ;-) Hi mate...err yes! Lol...I've checked all the obvious! Chain sprocket etc...going to av a play at weekend and see what's happnd....cheers anyway...
Post by nikfubar on Sept 15, 2011 20:18:18 GMT 1
Can you feel the selector drum rotating & clicking as you try to select the gears or is there very little resistance as you move the gear change lever
Post by critter on Sept 15, 2011 20:33:06 GMT 1
Can you feel the selector drum rotating & clicking as you try to select the gears or is there very little resistance as you move the gear change lever There is very little resistance as I move bike! I can't feel selector rotating :-(
Post by nikfubar on Sept 15, 2011 21:23:57 GMT 1
Yep the least you need to do is whip the clutch cover off I found that if you pussed the gear shaft from the chain side you can actually disengage the slector claw on the clutch side Only if the clutch casing has been removed
Post by critter on Sept 16, 2011 22:05:05 GMT 1
Just got as far as taking clutch to bits and it's completely burnt out! Never having one of these engines before, if the clutch goes do you get no drive as if you've got a box of neutrals....
Post by nikfubar on Sept 16, 2011 22:25:25 GMT 1
If it's completely burnt out I suppose so If you've got the clutch plates out try engaging the gears & turn the inner part of the clutch ( the bit thats on the end of the gear shaft ) this should turn the engine sprocket. If you can engage all 6 gears & neutral the gear box should be ok & you just need a new clutch. Norbo sells these I would use the HD clutch plates & springs.
