jonno
Post by jonno on Nov 29, 2005 22:01:21 GMT 1
Anyone got any recommendations for exhaust, filters etc. for a YPVS motor, that give the best allround performance without compromising reliability too much.
Thanks.
Post by nuttytart350 on Nov 29, 2005 22:42:55 GMT 1
Norbo's guidance on this is lightened flywheel £60 F2 pipes £250 boost bottle £25 carbon reeds £24 jet up 2 sizes £6 all parts from Norbo (prices are approx) keep the filter and air box
If i'm wrong Norbo please correct me as my memory sometimes plays tricks
Post by mellow on Nov 29, 2005 23:03:45 GMT 1
Geez nutty tart u seem to know ur stuff ;D
Post by vinze187 on Nov 30, 2005 10:13:42 GMT 1
Do K&N's do anything or do they leaken the mixture by to much or anything?
Post by vinze187 on Nov 30, 2005 10:53:45 GMT 1
but are there any down sides?
Post by vinze187 on Nov 30, 2005 14:06:04 GMT 1
Can you tell any performance change?
Post by nuttytart350 on Nov 30, 2005 19:30:06 GMT 1
but are there any down sides? I think you lose some bottom end - but gain max power - so it depends how fast you ride - are you throttle to the stop? - or do you prefer to pull? Then again - stuff that they look good and sound good
jonno
Post by jonno on Nov 30, 2005 19:37:49 GMT 1
Thanks Guys & Girls.
I dont have the original airbox so i think ill stick with shiny K&N's.
Post by nuttytart350 on Nov 30, 2005 19:46:02 GMT 1
Do K&N's do anything or do they leaken the mixture by to much or anything? i've just noticed the middle word - is that aimed at nutters22000?
Post by Norbo on Dec 1, 2005 10:26:49 GMT 1
Im not a fan of filteres. If i have to put them due to tuning or an air box just wont fit then i will . Filters take away bottom end and give a little mor right at the top. The main down side with them is They make the bike a little fluffy on the thotel and jeting can be a nightmare. When its cold your bike runs week and damp it runs rough worm it runs fine untill night rolls in and it gets cold or damp .Sopme bikes seem to do allright with them on but by far most do not . They can allso make a hot spot on the piston crown leeding to sezure or in some caces they can bit by bit eat the piston head away untill you get a holl.
