perence23
RD350 ypvs
Post by perence23 on Sept 8, 2011 19:04:27 GMT 1
i am thinking of doing an end can conversion on my f2 pipes and was wondering if anybody had any information or pictures on the subject thanks.
Post by nikfubar on Sept 8, 2011 19:58:44 GMT 1
Here's a set I did, just cut the old can off & welded on a mounting disc. NK racing also do this conversion if you want someone to do it for you ;D
Post by kennyroberts on Sept 8, 2011 20:40:49 GMT 1
perfect guys, thats just what im doing at the moment, how much were the cans? and where from? my big concern was that the end diameter was such a much larger diameter than most exhaust /can connection pipes, put this has put my mind to rest, i hoped to just weld on a flange mounting plate...cheers! im have also cut the downpipes off to weld some fresh ones on
Post by nikfubar on Sept 8, 2011 21:04:49 GMT 1
They were old arrow cans, got the pair off ebay for 40 quid
Post by kennyroberts on Sept 8, 2011 21:11:14 GMT 1
they look mint.....nice find!!!!!!!
Post by scott on Sept 8, 2011 21:50:27 GMT 1
Post by kennyroberts on Sept 8, 2011 21:54:42 GMT 1
nice job, do you need anything like a gasket or seal between the can and the expansion chambers?
Post by nikfubar on Sept 8, 2011 22:23:27 GMT 1
nice job, do you need anything like a gasket or seal between the can and the expansion chambers? Yeah I made a couple from gasket paper & sealed it with 3bond. No leaks ;D
Post by midlifecrisisrd on Sept 9, 2011 10:47:47 GMT 1
Done a set before, alloy cans and flanges from nk racing. Cut old can off and you will find a smaller diameter pipe inside ( stinger ) get some 25mm id 28mm od tube off ebay, fit over the smaller tube and you can use a large hammer to shape in the larger outer pipe then fill with weld and use a flapwheel to shape. Easier to fit the flanges to the 28mm pipe first as it is tight over the stinger so you can align it all before welding. Steve
