tony1
Post by tony1 on Aug 26, 2011 12:09:33 GMT 1
has anybody got a pic of one fitted to a bike i've seen them for sale but never fitted to a bike do they look ok or pants cheers
tony1
Post by tony1 on Aug 27, 2011 6:58:21 GMT 1
as in the title a 350 lc seat cowl makes it look like a single seat
Post by lcowner on Aug 27, 2011 11:55:59 GMT 1
tony1
Post by tony1 on Aug 27, 2011 16:38:04 GMT 1
i like the look of that one any pics of one fitted to a bike ??
Post by oldelsieboy on Aug 27, 2011 17:21:39 GMT 1
i like the look of that one any pics of one fitted to a bike ?? OEB
Post by sheep911uk on Aug 27, 2011 18:27:14 GMT 1
I had one on my lc in the 80s and it looked terrible,the lines just dont flow!!
Post by robin on Aug 27, 2011 20:58:50 GMT 1
Not a solo seat as such but a cover for the standard seat, tried it on the bike with and without the grab rail, even with my carbon Fiber tail piece, but still not a pleasing look, just not quite right if you know what I mean.
Post by t500racer on Aug 27, 2011 22:09:15 GMT 1
I purchased one of the 350 LC solo seat cowls on Ebay (same as above in Robins post). Im not happy with it. It doesn't look all that good, doesn't really flow with the tailpiece, where the fibreglass is cut to fit around the seat is not cut evenly or professionally at all and it shows when mounted, the edge of the fiberglass that contacts the seat will wear and cut into the seat cover. If your seat does not sit flat against the tailpiece (as most of the stock seats don't), the seat lifts the cowl away from the tailpiece and really makes it look like shite. I had to drill holes in the seat pan for zip ties to hold the rear of the seat down and make the cowl and tailpiece sit flush together. A royal pain in the ass when you need to remove the seat! The worst part is that to fit this you have to cut into your seat cover to bolt it into place. This is not made clear in the description, I should have investigated more thoroughly, as I ruined a perfect stock seat. I have had this cowl for 2 years now and the gelcoat is lifting off the fibreglass, creating very unsightly bubbles. Complete waste of money.
I have been trying to find a Pichler or Guiliari seat but I always seem to miss the auctions when they come up on Ebay.
tony1
Post by tony1 on Aug 28, 2011 7:02:43 GMT 1
excellent pics lads i might go for the proper solo seat unit
Post by johnlc on Aug 28, 2011 7:34:55 GMT 1
I like this one better lines flow a lot better can be had for £90 from ard racing newcastle
Post by buckshot on Aug 28, 2011 7:47:17 GMT 1
Now thats a lot better,looks good to me,although not much padding for my arse. But I like it.
Dave.
Post by oldelsieboy on Aug 28, 2011 9:16:40 GMT 1
I like this one better lines flow a lot better can be had for £90 from ard racing newcastle Isnt that a complete all in one tank cover & seat unit? OEB
Post by johnlc on Aug 28, 2011 9:21:12 GMT 1
you can get this with tank cover or without
Post by lcowner on Aug 28, 2011 9:36:07 GMT 1
yep that looks way better even better if u split the seat pad like on modern race bikes
tony1
Post by tony1 on Sept 4, 2011 20:27:14 GMT 1
i've bought one of the mead speed ones looks good quality but how do you line it up to mark the hole that need drilling as you can't see them or am i being stupid
Post by lcowner on Sept 4, 2011 22:46:38 GMT 1
a lttle trick i used to use was if u get a bolt ,ccut the head of it and grind a point on it wer the head used to be. screw the modified bolts into the mounting points.then trial fit the seat unit but wen fitting it 'pull' the the seat unit apart slightly until in place. then when in position push it against the pointy bits and it will leave a mark on the inside of the seat unit wer u want the holes. id try it a few times before drilling to get in the ball park.........
tony1
Post by tony1 on Sept 5, 2011 17:39:31 GMT 1
good idea i'll try that cheers
