Post by gladders on Aug 20, 2011 22:42:32 GMT 1
Has anyone got a metmachex swingarm and can tell me how the eccentric chain adjustment works? Cheers Grant
Post by billbott on Aug 21, 2011 12:35:21 GMT 1
Loosen off the spindle nut, then the 2 + 2 off m8 bolts in the eccentrics. Then rotate the eccentrics using the spindle hexagon, untill correct tension is achieved. Tighten the 2 + 2 bolts, tighten the spindle nut and the jobs a good 'un. If its all working correctly, both eccentrics are keyed in line so they both move at the same time. PM me for my number if you don't follow.
Post by gladders on Aug 21, 2011 20:37:33 GMT 1
Loosen off the spindle nut, then the 2 + 2 off m8 bolts in the eccentrics. Then rotate the eccentrics using the spindle hexagon, untill correct tension is achieved. Tighten the 2 + 2 bolts, tighten the spindle nut and the jobs a good 'un. If its all working correctly, both eccentrics are keyed in line so they both move at the same time. PM me for my number if you don't follow. Cheers Billbott, sounds fairly straight forward. I'll give it a go and let you know how I get on
