perence23
RD350 ypvs
Post by perence23 on Aug 17, 2011 23:09:17 GMT 1
will TRIUMPH T509 SPEED TRIPLE 1998 fit my 350 ypvs f1 and mount straight on i know them are 83mm bolt spacing. But will the offset match the discs thanks.
Wez350
Post by Wez350 on Aug 17, 2011 23:23:59 GMT 1
These are Triumph calipers on a f1/2 front end See for sale section
perence23
RD350 ypvs
Post by perence23 on Aug 18, 2011 11:37:02 GMT 1
How much would you sell just the calipers thanks
Post by paddyontour on Aug 18, 2011 12:02:01 GMT 1
Have a set on my F2 mate - mahoosive improvement in braking, so much so that I'd advise you spend a little time getting used to them after you fit them 'cos you go from having to pull with all yer might, to being able to use one finger ;D and they bolt straight on and match up to the disc perfectly - never looked back since fitting them
Post by andygraham on Aug 18, 2011 13:53:09 GMT 1
Will these fit the LC1?
perence23
RD350 ypvs
Post by perence23 on Aug 18, 2011 13:59:57 GMT 1
The calipers off a t595 and t509 are the same and fit if you have an 83mm bolt spacing. Or the same calipers as an f1 or f2.
Post by andygraham on Aug 18, 2011 15:47:12 GMT 1
Has the Lc 83mm mounting holes anybody?
Post by LC_BOTT on Aug 18, 2011 17:23:26 GMT 1
No they won't fit an LC or the early YPVS, not exactly sure which model, but from F2 etc onwards
Post by andygraham on Aug 18, 2011 18:00:45 GMT 1
Thanks Lc bott appreciated
Post by JonW on Aug 19, 2011 0:09:03 GMT 1
They fit the '85 F1 on.... basically anything with the later fork bottoms, ie if they say 'variable damper' these will fit.
Do make sure you buy the right ones...only certain calipers are 83mm, the rest are 90. Ive been there and bought the wrong ones. I also think rebuild kits are not cheap for them, but many are in good nick as Trumpet guys look after their bikes it seems.
Post by JonW on Aug 19, 2011 2:12:09 GMT 1
Ok its taken ages but i found my photos... I was going to do this stuff on a website for my bike, but here you go guys, i dont want people to make the expensive mistakes i did These were 90mm and didnt fit: These were 83mm and fit... You would be better off asking the seller to measure the calipers, but down here Triumph calipers are rare and i had to take a punt both times as the seller ignored my requests to measure the things, sigh...
Post by davey on Aug 19, 2011 8:43:01 GMT 1
does anyone out there know what calpier will fit a 250 lc without to much hassle
perence23
RD350 ypvs
Post by perence23 on Aug 19, 2011 15:38:30 GMT 1
I have the second ones you have pictured with the 83mm they are for my f1 and should be fine but i get them tomorrow so i will update tomorrow night with my findings
Post by JonW on Aug 20, 2011 0:21:33 GMT 1
Cool, I reckon you will be fine with those
perence23
RD350 ypvs
Post by perence23 on Aug 20, 2011 17:00:20 GMT 1
Calipers have not come even though they where parcelforce 48 hours :/
Post by oldelsieboy on Aug 20, 2011 18:14:18 GMT 1
does anyone out there know what calpier will fit a 250 lc without to much hassle Only the later LC2 (31k) calipers are a bolt on replacement, but most all others will fit if the relevant brackets are manufactured/fitted. HTH OEB
Post by davey on Aug 21, 2011 8:02:16 GMT 1
thanks OEB
perence23
RD350 ypvs
Post by perence23 on Aug 23, 2011 22:06:03 GMT 1
Fitted the calipers today fitted straight on just as easy as the stock ones . And they are also nice and suttle which i also quite like.
marjay
Post by marjay on Sept 2, 2011 11:47:25 GMT 1
I found some Triumph TT600 calipers on fleabay and they bolted straight on to my F2 with no issue. A vast improvement in braking. I had the good fortune to own a Speed Four at the time, so I was able to remove the calipers and test fit them etc. I do think I was very lucky to get the TT600 calipers for £30 though!
Post by JonW on Sept 3, 2011 0:36:47 GMT 1
Cool, really glad this is working out for people. I still havent fitted my set yet to a running bike for testing but have to be better than the manky set on it when i got it. I now have an RGV250 Master cylinder I may run as well if i cant be bothered to rebuild the standard setup as its pretty trashed.
So, anyone remove the Triumph logo? Im not sure if i want to or just leave it... its no worse / better than Tokico or Brembo.... hmm...
perence23
RD350 ypvs
Post by perence23 on Sept 3, 2011 8:25:33 GMT 1
Ive left mine on for the time being but it will be coming off, Im going smooth them off so they are silver and put a yamaha gel tuning fork on each of the pots so it will match it in with tihe bike a little more. Think i will look nice.
Post by JonW on Sept 3, 2011 23:55:13 GMT 1
Sounds like a nice idea. Will be interested to see the pics.
Post by paddyontour on Sept 5, 2011 12:05:51 GMT 1
Post by rabbit57 on Sept 7, 2011 14:11:31 GMT 1
Bought some tt600 calipers for £45. Seems to be a good cheap upgrade at the moment if you shop around on e-bay.Bob.
