Post by davey on Aug 16, 2011 2:49:02 GMT 1
hi all, what grade oil is the best for the gearbox on me 250 lc. can i use a good engine oil ie semi or fully synthetic, and any tips on flushing out and a good interior clean after draining before replacing with the new oil would be much app,thanks
Dave
Post by bare on Aug 16, 2011 4:24:33 GMT 1
GL4 gear oil 75/85 w
Post by Norbo on Aug 16, 2011 8:24:58 GMT 1
If your not taking of the casing and just draining from the sump bolt then i would do it after a ride get it nice and worm then do it . Id use any good quolity Light gear oil i use MOTUL Transoil 10W30 and Transoil Expert 10W40 depending on the bike.
Post by stanlc7189 on Aug 17, 2011 1:38:32 GMT 1
I've just put in Castrol GPS 10W40 synthetic m/c engine oil following a re-build. Same stuff I put in my GSX-R750k5. Supposedly good wet-clutch performance. I've had no problems in the Gixxer's gearbox/clutch dealing with 150 bhp, so 47 bhp going through the Yam's gearbox shouldn't create any problems.
