Post by weegiboy on Aug 15, 2011 21:46:11 GMT 1
How Do All So i refurbbed a pair of vj22 front disks( masking and spraying ) but some of the big earing type eyes that connect the disk to the mounting central span are slightly loose , should i give up now or is there a way salvaging these ? As green back is tight :-(
Post by nikfubar on Aug 15, 2011 22:16:55 GMT 1
It depends how sloppy they are, a little left/right play is ok but if they move in & out they are fooked You will find if they have play in them they will chatter a bit when you apply & release the brakes.
Post by Norbo on Aug 16, 2011 8:42:39 GMT 1
Remember they are floating disks and are ment to have some movemant that why they are caled floating dosks . You should hear TZ disks they rattle like a bag of spanners .
Post by weegiboy on Aug 18, 2011 12:24:29 GMT 1
Ok thanks lads they aren't moving massively only slightly , weird they were ok then i hung them up during refurbing them and left them to dry after painting just wondering if this has caused them to give a little , they will do for now just to get it to a complete then i reckon it's wavy disk on the crimbo list . cheers wb :-)
Post by JonW on Aug 19, 2011 0:34:31 GMT 1
Im doing a set of these at the moment. The rattle if you shake them isnt quite maracas, but Bez could use em at a pinch Any tips with the refurbing of these?
