Post by critter on Aug 15, 2011 20:31:02 GMT 1
Hi... Can someone tell me the fuel flow rate on a 350 YPVS fuel Tap...? Thanks for your help.... Paul....
Post by Norbo on Aug 16, 2011 8:21:17 GMT 1
This is something i have never even thourght about . Why do you need to know . I dont think there is any stat on this . i can tell you however that if you are using biger carbs then you need to upgrade to a 8mm tap insted of the 6mm standard outlet .
Post by critter on Aug 16, 2011 12:02:23 GMT 1
This is something i have never even thourght about . Why do you need to know . I dont think there is any stat on this . i can tell you however that if you are using biger carbs then you need to upgrade to a 8mm tap insted of the 6mm standard outlet . Im building a hybrid and not using standard tank or tap...I dont fancy starving engine of fuel by using wrong tap so needed to know flow rate....i think ill time std tank tap flow into a container and do it myself....sorry but thought someone on here might know....thanks for your help anyway....
Post by Norbo on Aug 16, 2011 17:37:51 GMT 1
If you post your findings the next time some askes we will know. Thats the good thing about the forum as new people join they bring theknolage they have and it helps every one .
But i think you just need an 8mm tap out put with a 8mm splitter and some 8mm fuel pipe . Thats what they use on TZ's that feed 38mm carbs and what they use on RGV's and if im not wrong i think its an 8mm tap on most 28mm carb set ups as well .
Post by critter on Aug 17, 2011 19:29:48 GMT 1
If you post your findings the next time some askes we will know. Thats the good thing about the forum as new people join they bring theknolage they have and it helps every one . But i think you just need an 8mm tap out put with a 8mm splitter and some 8mm fuel pipe . Thats what they use on TZ's that feed 38mm carbs and what they use on RGV's and if im not wrong i think its an 8mm tap on most 28mm carb set ups as well . Flow rate: 1 pint in 20.6 seconds
Post by sulli on Aug 18, 2011 12:49:55 GMT 1
So that's 3 pints a minute quick calc that 1.7 liters a minute That means you would empty the tank in about 10.58823529 minutes So 10 minutes at 60kph gives you a range of 6km based on a 18 liter tank means consumption of 3l per km So based on the flow rate you could nearly run a V8 bog stock Now open to flaming LOL
