daveg
ProClassic
Post by daveg on Aug 15, 2011 12:39:50 GMT 1
Probably been asked a million times.... but can you change the oil seal without splitting the crankcases? Mine has just started leaking this weekend!
Post by andygraham on Aug 15, 2011 12:56:41 GMT 1
yes mate easy fix norbo sells them
daveg
ProClassic
Post by daveg on Aug 15, 2011 14:31:21 GMT 1
Great thx. Do you have to remove the gear shaft to get the old one out - is there anything I need to know?
Post by andygraham on Aug 15, 2011 16:45:16 GMT 1
Take the sprocket and tab washer off Pride the old one off. Thin screwdriver will do.apply a smidge of grease to the new seal. Tap into place.I used a large socket.job done
daveg
ProClassic
Post by daveg on Aug 15, 2011 17:47:22 GMT 1
fantastic - thx for your help!
Post by paddyontour on Aug 16, 2011 11:32:45 GMT 1
I bought a new one off Norbo the last time I was getting bits, so I'm gonna give this a try myself - sorry to hijack your thread mate but I was wondering if you could also replace the Gear Selector Shaft Bush without splitting the cases?
Post by andygraham on Aug 16, 2011 13:59:41 GMT 1
Wondering the same myself Might be a job getting the old one out tho I'm sure Norbo will be along to shed some light on it
Post by JonW on Aug 16, 2011 14:15:52 GMT 1
if you use a small pick you might get the gear selector shaft one out, but since its leaking anyway why not try I guess. Another way is to screw a self tapper into a seal to help get it out, but... that seal is small and thin so I wouldnt recommend that approach.
Post by nikfubar on Aug 16, 2011 16:54:52 GMT 1
They come out easy with a small screw driver
