stuboy
Post by stuboy on Aug 13, 2011 16:06:37 GMT 1
I had another go at trying to get rid of the very bad flat spot on my 350 Elsie the other night. Got stage 1 tune, Micron large Cans, Standard airbox, 31k carbs, boost bottle and spacer blocks. Atm had 200 main jets and very bad stutter between 6-7k then it flies 220 main jet still stutters but statter starts lower and is not quite as bad at 5.5k - 7k then it flies 230 main jets and the stutter starts at 4.5 k and it wont pull through it even in a low gear. Low to midrange is great and above 7k is awesome. Could the issue be the needles or the nozzle ? It is looking like ditch the Microns or a trip to Stan Stevens to sort it out !!! Has anyone got an elsie with Microns that runs good ?!!!
Post by elsie1411 on Aug 13, 2011 18:04:51 GMT 1
had a similar set up to you mate and i had to remove part of the airbox lid to get it to run better then it decided to eat a piston so went back to 4l0 carbs. you must do a plug chop with the lid modded as with 230 jets it ran slightly weak at full chat i also had a standard filter fitted too
Post by 1260dave on Aug 13, 2011 23:04:16 GMT 1
i've got 31k carbs on my bike with 290 mains with dark tan coloured plugs swarbrick f2's, k+n filters, mick abbey tuned, 4lo needles, 22.5 pilots, it doesn't run too bad i can't see the microns being a problem, sounds like blocked pilots to me
Post by soccersmyth on Aug 14, 2011 18:55:24 GMT 1
Would it not be more sensible to invest in a 2 stroke specialist who has a dyno. I know that's what i'll be doing when the time comes.
Post by soad1110 on Aug 16, 2011 0:52:09 GMT 1
I'd use Bob Farnham instead of Stan, he's a top bloke and loves the old smokers!
