Post by chaz1234 on Jul 2, 2011 9:23:16 GMT 1
Hi, I'm after some expansion chambers for my 350 YPVS, will RD350LC ones fit OK and work?
Any advice would be appreciated.
Cheers, Sam
Post by oldelsieboy on Jul 2, 2011 11:38:12 GMT 1
Hi, I'm after some expansion chambers for my 350 YPVS, will RD350LC ones fit OK and work? Any advice would be appreciated. Cheers, Sam ANSWERED HERE OEB
Post by Deleted on Aug 9, 2011 21:28:34 GMT 1
hi mate will not work you will be down on power if you put lc pipes on
Post by Norbo on Aug 10, 2011 7:16:33 GMT 1
The pipes will fit if you elongate the holl so Yes they will fit . But would i fit them well no . The chamber on a ypvs is bigger then an lc on most pipes except Microns they are the same pipe the bracket was just welded on further back so unless is microns your fitting id stick to YPVS pipes made for a ypvs . thats my 2p worth .
