Post by weegiboy on Aug 7, 2011 11:51:52 GMT 1
How Do All So i got my swinger back from NK racing (nice job) , yesterday i tried to pop it in but it wasn't happening ? do you use the original exterior RGV end caps that pop on each end of the swinger ? i popped it in without them and it seemed to seat in easier i never bolted it up as i wasn't sure if this was the way forward so left until i spoke yo you guy's , i put the bearings in etc which is all good except one side the outer bearing edge is protruding out by about a half to full mm , tried to get it flush using the correct sized socket , would this make a difference ? All advice and help greatly received . Thanks wb
Post by weegiboy on Aug 11, 2011 23:27:47 GMT 1
Got it in just took the shims out and the end caps are a perfect fit , how tight should the nut on the swinger bolt be ? Cheers wb :-)
