Post by aaronben40 on Jul 29, 2011 22:22:12 GMT 1
My 350 is really hesitant around 4500 rpm up to 6,000 where it gets less hesitant. Cant tell what its like above that cos still running it in after a full rebuild. I've tried a different coil and a different CDI and different plugs but its still the same. The loom is brand new as are the ignition switch, and all other electrical bits. Could it be fueling and if so anyone any ideas how to cure it. Its a standard set up on standard jettiong with bog standard pipes.
Post by 1260dave on Jul 30, 2011 0:48:32 GMT 1
have you checked the pilot jet isn't blocked, you could try moving the jet needle up or down a notch
Post by aaronben40 on Jul 30, 2011 10:08:24 GMT 1
Must admit i did not put new needles into the carbs just used the kits from Norbo with new jets. I will give it a go
Post by looey on Jul 30, 2011 11:34:16 GMT 1
Try dropping the needles one clip (move the clip one notch nearer the top/end).
Post by oldelsieboy on Jul 30, 2011 11:58:49 GMT 1
Before making any changes make sure you have the correct needles (5K1) fitted & the clip is in the middle groove/slot.
OEB
Post by aaronben40 on Jul 30, 2011 23:37:06 GMT 1
Does Norbo do the needles?
