Post by paulrevs on Jul 26, 2011 23:15:16 GMT 1
Hope someone can help me
Have removed and refitted the fuel tank on my f2 and noticed when refitting that vacuum pipe that goes on the fuel tap has a "t" piece with another pipe going pie not conected to anything.
Had a look and cant seem to see where it connects to.
Any pictures or advice on where the vacuum pipes connect would be brilliant thanks.
Post by nikfubar on Jul 26, 2011 23:20:38 GMT 1
The fuel tap has two outlets one big & one small. The small one goes to the vacume pipe & the big one connects to the T piece & from the T piece you have a fuel pipe going to each carb
Post by paulrevs on Jul 26, 2011 23:25:00 GMT 1
Thanks for the reply.
The large bore pipe is fine and connected to both carbs. This is the small bore pipe and also has a t piece in it ??
Post by nikfubar on Jul 27, 2011 0:22:53 GMT 1
Has your bike got a scott oiler fitted it's the only other thing I can think of that requires a vacume feed pipe.
