Lugs
Jul 22, 2011 23:01:43 GMT 1
Post by weegiboy on Jul 22, 2011 23:01:43 GMT 1
How Do All Can anyone tell me the correct measurements to use for placing M8 or M10 bolts on the bottom yoke of my RGV VJ22 front end to replace the old lugs that i will cut off , im putting it on a 4L1 frame , also is tap n die a difficult thing to do ? taking in to consideration im a newbe and can easily break things ! but realising this is what has to be done all input appreciated . Thanks wb
Lugs
Jul 23, 2011 0:43:55 GMT 1
Post by nikfubar on Jul 23, 2011 0:43:55 GMT 1
When I did mine I just fitted forks & tank then marked how far the bottom yoke could go before it hits the tank. As a guide, if you look at the bottom of the lower yoke there are 2 threads allready in the bottom, they basically end up where you need to fit the M8 bolts
Lugs
Jul 23, 2011 1:56:01 GMT 1
Post by weegiboy on Jul 23, 2011 1:56:01 GMT 1
Nice one thanks that's really helped wb :-)
