perence23
RD350 ypvs
Post by perence23 on Jul 20, 2011 23:27:29 GMT 1
I have seen a few Rd500 kickstarts on 350 ypvs's and i was wondering how you attach them on because everyone seems to have a bolt and washer though the kickstart mechism to hold it on is this the only way thanks perry
Post by onewheelsenough on Jul 20, 2011 23:54:39 GMT 1
you can either drill and tap your kickstart unit then use a big washer and bolt. or mod you original kicker knuckle cheers gaz
Post by Norbo on Jul 21, 2011 8:03:13 GMT 1
Yes as above some people just stick it on a standard kick start bottom . I allways drill and use the bolt as they look better with the bifg alloy 500 botom part i think .
perence23
RD350 ypvs
Post by perence23 on Jul 25, 2011 11:58:10 GMT 1
I have drilled and tapped the unit and fitted the kickstart but i cannot stop it hitting the engine casing. Even when i move it back it rocks forwards and still hits it any ideas?.
Post by oldelsieboy on Jul 25, 2011 12:10:14 GMT 1
I have drilled and tapped the unit and fitted the kickstart but i cannot stop it hitting the engine casing. Even when i move it back it rocks forwards and still hits it any ideas?. No problems with mine, but I did weld the inner boss to the main kickstart. OEB
perence23
RD350 ypvs
Post by perence23 on Jul 25, 2011 12:27:26 GMT 1
Yes that would work because it would stop it from rotating around the centre. I will give that ago thanks
