Pulling
Jul 19, 2011 19:51:26 GMT 1
Post by airbraker on Jul 19, 2011 19:51:26 GMT 1
Got a standard RD250LC. Standard pipes, standard plugs, standard exhaust, standard carbs (250 jets) needles set correct. Air-box standard. Oil pump set correctly. Plugs are tan electrode and porcelain but dry black round ring except for one fifth which is clear of any black (on both plugs). Haven't done a chop yet just run as normal. Anyway I get it in third and let the revs rise to about 8 thou ish and instead of pulling trough it kind of runs out of puff. Doesn't splutter just stops pulling. Feels like a limiter but gentle. Is it supposed to just keep pulling through or do they do that ? I didn't push hard just went up to forth and it did it again. Almost feels like gearing but sure its not ...... any thoughts ?
Post by Norbo on Jul 21, 2011 8:21:22 GMT 1
I wunder if the Hi end coils are braking down. sounds like there is something not quight right they should rev clean to 9.5 .
Pulling
Jul 21, 2011 17:05:27 GMT 1
Post by Tone on Jul 21, 2011 17:05:27 GMT 1
The data I have says the main jets should be #190 on carbs marked 4L100.
Pulling
Jul 21, 2011 18:08:11 GMT 1
Post by twostroker on Jul 21, 2011 18:08:11 GMT 1
if its a imported bike maybe restricted pipes?
Pulling
Jul 22, 2011 22:29:12 GMT 1
Post by airbraker on Jul 22, 2011 22:29:12 GMT 1
No uk bike so pipes are or should be ok but the coil bit is a littel interesting I thought of that before and changed coil but it was second hand again cus you cant buy knew !
