Post by weegiboy on Jul 19, 2011 0:54:30 GMT 1
So this is what i started with and then it just keeps going the frame is in great nick and decided not to get it PC...
Post by weegiboy on Jul 19, 2011 0:57:50 GMT 1
Sent this off to NK Racing should get it back today hopefully all sorted , im going to etch prime then put 3-4 coats of primer then paint satin black i think Started to strip back the tank ! found a couple of small holes on the underneath bollocks , do you think i can get them fixed ? http: //i1202.photobucket.com/albums/bb365/weegilookatit/th_DSC_0263.jpg[/IMG][/URL]
Post by weegiboy on Jul 19, 2011 19:20:02 GMT 1
before and after i had a go for the first time at polishing , i think i could do better
Post by midlifecrisisrd on Jul 19, 2011 19:42:25 GMT 1
Sent this off to NK Racing should get it back today hopefully all sorted , im going to etch prime then put 3-4 coats of primer then paint satin black i think Started to strip back the tank ! found a couple of small holes on the underneath bollocks , do you think i can get them fixed ? http: //i1202.photobucket.com/albums/bb365/weegilookatit/th_DSC_0263.jpg[/IMG][/URL] [/quote] Tank holes can be blasted then brazed up, as long as it is solid enough around them. Steve
Post by weegiboy on Jul 19, 2011 19:53:19 GMT 1
Thanks Steve they are small and round them is quite solid and not feathering away so i reckon they could be brazed :-) do you think the brazing will be expensive ? Do you know a gestimate that i can go on for when i get quotes ? Many thanks wb
Post by weegiboy on Jul 19, 2011 20:02:02 GMT 1
Bought this told it has done apprx 500 miles since re-bore , number on pistons is 0.5 , i've took blocks ,head,barrels, side casings off , oil and water pump out , spraying side casings putting new gaskets on , not stripping and blasting cases as im not confident enough yet to deal with the crank and gear box.... Picture of the piston head
Post by midlifecrisisrd on Jul 19, 2011 20:03:15 GMT 1
Thanks Steve they are small and round them is quite solid and not feathering away so i reckon they could be brazed :-) do you think the brazing will be expensive ? Do you know a gestimate that i can go on for when i get quotes ? Many thanks wb Should not cost much at all, do you not know anyone with oxy aceteline. Even B&Q do pre fluxed brazing rods. Are you still looking for lc clocks, got a set I'm considering selling. Was going to put them on the Lc2 but not sure now, even got new cases from Norbo still in their bags. Owe me £170 though Steve
Post by weegiboy on Jul 19, 2011 20:06:17 GMT 1
Thanks for the heads up n offer but got a set a few weeks back (nice ones)must update that thread cheers wb
Post by weegiboy on Jul 19, 2011 20:09:08 GMT 1
Could i do the brazing myself with the rods and a handheld gas blow torch ? Or does it not get hot enough ? Thanks wb
Post by lcowner on Jul 19, 2011 20:10:32 GMT 1
thats what i was just about to ask wb...............
Post by weegiboy on Jul 19, 2011 20:12:53 GMT 1
I reckon if it works i'll be havin a go myself , if so i will let you know how it goes RD N wb :-)
Post by weegiboy on Jul 19, 2011 20:35:55 GMT 1
Fair bit to go yet
Post by midlifecrisisrd on Jul 19, 2011 20:56:38 GMT 1
Could i do the brazing myself with the rods and a handheld gas blow torch ? Or does it not get hot enough ? Thanks wb Brazing rods melt at about 900 degrees and you can get a mixed gas torch that is 1400 degrees but that is flame temp and not the temperature the metal will get to as it will dissapate the heat. Will be about £40 for one and not sure it would work, did buy a cheaper one that was not as hot and would not work. Might be worth trying leading as this will work with a blow lamp and some flux. Either that or silver soldering. Try googling them. Steve
Post by weegiboy on Jul 19, 2011 21:16:11 GMT 1
Ok will have a look and see if im up to it . wb
Post by weegiboy on Jul 19, 2011 21:29:24 GMT 1
What about JB Weld or is that not suitable for this job ? wb
Post by weegiboy on Jul 23, 2011 0:28:28 GMT 1
Decide to get it brazed , then clean it up and paint it , here's some other stuff that's being seen to this has been blasted im now layering up the primer at mo , this one to head bearings on the way , next get a spacer from Norbo , NK done a great job on the swinger and top yoke , swinger off to get PC satin black , im doing the yoke etc myself , will post pics when done , had bad day with engine but won't go in to that to depressing but lessons learned the hard way lets leave it at that.................. So today i concentrated on the wheels first time i've ever done this but so far i haven't bodged i think , going to let them dry for a week...
Post by weegiboy on Aug 2, 2011 13:37:32 GMT 1
Turns out the tank is a bit shat on the under side but maybe will come good with some solder flow , should do till such time as i can afford a decent one ££££ ! Bit slow at mo with work etc hopefully more pics soon to show i haven't been doing nothing , swinger should be back by the weekend all PC'd up wb :-)
Post by weegiboy on Aug 15, 2011 21:21:55 GMT 1
Thanks MidLifeCrisis they came up nice :-) I have tackled the inside surfaces too :-)
Post by midlifecrisisrd on Aug 15, 2011 21:54:39 GMT 1
No problem, glad to help, they were just gathering dust, going to have a clearout I think.
Post by weegiboy on Nov 21, 2011 22:16:02 GMT 1
How Do It's been a while but here goes , not been sitting on my arse honest , been putting engine together and tackling everything else as i go which means building then taking apart , i know ( it's what happens as a newbie first timer :-) ) , but getting there slowly in between work and life , have decided to build as is without tarting it up want to get it up and running and worry about looks later , here are some run of the mill picks for now :-)
Post by JonW on Nov 22, 2011 2:47:19 GMT 1
Looks good, lots of progress!
Post by weegiboy on Nov 22, 2011 11:10:40 GMT 1
Thanks John the learning curve is also a work in progress :-) , i haven't sorted the steering lock stops but couldn't resist mocking up as i go and i thought the more i put together and take apart again the more familiar i'll get plus better at fettling the machine , i was going to ask you what speedo cable did you use to go from your rgv speedo to your rd clocks ? wb :-)
Post by midlifecrisisrd on Nov 22, 2011 13:16:28 GMT 1
Thanks John the learning curve is also a work in progress :-) , i haven't sorted the steering lock stops but couldn't resist mocking up as i go and i thought the more i put together and take apart again the more familiar i'll get plus better at fettling the machine , i was going to ask you what speedo cable did you use to go from your rgv speedo to your rd clocks ? wb :-) Good to see you getting back into it. Have you tried the rgv cable to see if it is long enough, genuine ones are longer than pattern. I used a 600 bandit cable, you just have to cut the slot wider and a bit deeper at the bottom to get it to fit. Steve
Post by weegiboy on Nov 22, 2011 18:13:29 GMT 1
Hi Steve Thanks for that i think i remember you telling me this before , that's it straight on to fleabay for a bandit one hacksaw at the ready , had a quiteer day in the garage , took the ypvs rear master cylinder apart and polished it but the little screw that holds the pipe to the main body was f%@ked and sheered aaaggghhh tried to drill out but stopped before i made it worse thinking of just bonding it on !! , but the master cylinder came up nice , spent time just looking at the back brake/cylinder set up and thinking about how i can extend the metal arm that comes down to the pedal , Norbo mentioned welding a bit of metal on , thing is i only ever welded once in metal work when i was fourteen Lol ! , and watching the penny's so we'll see , also need to get a spring for that set up as well , but all very therapeutic even when shit goes wrong , to all i will start to take more pics when im not so distracted , tomorrow is soldering the wiring of the headlamp now that i know i won't make a hash of :-) wb
Post by weegiboy on Nov 22, 2011 18:16:29 GMT 1
One lesson learned i re-furbished the forks n wheels myself using alloy wheel paint to save on powder coating.................. yip you guessed it , bloody chipping already well you get the idea as i said more important to get it up n running the tarting can come later. wb
Post by ianmac on Nov 23, 2011 8:07:36 GMT 1
Looking good......
Post by billyboy on Nov 25, 2011 14:54:59 GMT 1
+1 looking gr8 fella
