Post by weegiboy on Jul 17, 2011 14:49:41 GMT 1
How Do I've stripped both front Tokicos , cleaned up the pistons and chambers etc , all seem fine my question is this , all the seals i removed seem fine , no perishing no cracks or chunks out of them , do you think it's ok to re use them ? Or is that out of the question ? Thanks wb
Eyeore
Post by Eyeore on Jul 17, 2011 17:43:27 GMT 1
I've often re-used them, however if you haven't kept them in brake fluid you may well find they have swelled up and will no longer fit.
Post by weegiboy on Jul 17, 2011 20:26:41 GMT 1
Ok F!!K , they haven't been kept in brake fluid , gulp ,new seals it is then !! , when you say red rubber grease do you mean when fitting the seals only ? Thanks for all your help lads .
wb
