Post by charlie on Jul 16, 2011 16:58:46 GMT 1
I have a problem with rust in my petrol tank,has anyone successfully solved the same problem with a tank sealant. I would be glad of your advice. yours with thanks.
Post by lcowner on Jul 16, 2011 17:44:22 GMT 1
por15 is supposed to be the job but then again ive heard conflicting reports lately,wer is it rust?
Post by charlie on Jul 17, 2011 7:01:26 GMT 1
thanks for your reply,its been unused for a long while the rust is over most of the inside.
neil
my 125
Post by neil on Jul 17, 2011 14:02:48 GMT 1
i filled mine with clean shingle and shook it for ages. one i did hear was to put nuts and bolts in wrap the tank in an old duvet and let it spin in a cement mixer.
Post by mark350lc on Jul 17, 2011 18:08:08 GMT 1
I've always used Por15 in the past with good results. Trying something different this time.
Have got a nasty lc tank full of rust and pinholes. After talking to my painter he suggested chemically stripping the tank to remove rust and paint then welding up the pinholes. It is then zinc plated inside and out.
Should get it back in a couple of weeks. Will post results.
chez
Post by chez on Jul 17, 2011 20:55:52 GMT 1
I've always used Por15 in the past with good results. Trying something different this time. Have got a nasty lc tank full of rust and pinholes. After talking to my painter he suggested chemically stripping the tank to remove rust and paint then welding up the pinholes. It is then zinc plated inside and out. Should get it back in a couple of weeks. Will post results. Mark is that the place in preston sounds intresting he did show me a lawn mower tank
Post by davey on Jul 18, 2011 11:01:20 GMT 1
if the tank is zinc plated on the outside too will the paint stick
Post by mark350lc on Jul 18, 2011 21:04:49 GMT 1
Hib Col, yes I think it is the place in Preston. Did the tank he showed you look ok? Also with your experience, what do you think about the paint sticking?
