Post by lcowner on Jul 16, 2011 10:48:07 GMT 1
i am running 16t front sprocket on my 4lo. i want to change it to give me more bottom end drive in the low gears.im not worried abot top end speed and dont mind loosing a bit.what do i need to do go up to 17 or down to 15 .i know i cud change rear sprocket but it suits me better at the mo to change the front.............
Post by Tone on Jul 16, 2011 11:08:50 GMT 1
To lower the gearing i.e to give better acceleration you need to go down on the front or bigger on the back so by putting on a 15 front you will lower the gearing. Tone
Post by lcowner on Jul 16, 2011 17:42:46 GMT 1
thanx,is it 1 on front means 3 on back ive heard tone?
Post by lcowner on Jul 17, 2011 13:30:35 GMT 1
cheers m8
Post by 1260dave on Jul 17, 2011 19:56:20 GMT 1
i've got a 15 on the front and a 40 on the back, i spend alot of time lookin at the clouds
Post by lcowner on Jul 17, 2011 22:34:52 GMT 1
i've got a 15 on the front and a 40 on the back, i spend alot of time lookin at the clouds ;D
Post by lcowner on Jul 17, 2011 22:56:21 GMT 1
anyone got a newish 15 they wanna swap for a newish 16???
Post by winnerevo1 on Jul 20, 2011 20:25:40 GMT 1
Be aware when dropping teeth off the front that you make the chain run smaller, i.e the chain has to take a smaller route and can cause extra stress on the chain.....
not to mention your chain adjusters will have to go further back and your swingarm clearance may be compromised.
1 tooth will probably be OK but if I was doing it I'd go up on the back.
Post by lcowner on Jul 21, 2011 0:41:58 GMT 1
Be aware when dropping teeth off the front that you make the chain run smaller, i.e the chain has to take a smaller route and can cause extra stress on the chain..... not to mention your chain adjusters will have to go further back and your swingarm clearance may be compromised. 1 tooth will probably be OK but if I was doing it I'd go up on the back. thanx for the advice as im tight for chain clearance as it is, so maybe not a good idea after all
Post by lcowner on Jul 22, 2011 9:40:01 GMT 1
cheers chaps,im too old for redlining gary.................... ;D
Wez350
Post by Wez350 on Jul 22, 2011 10:42:23 GMT 1
Hi mate can you contact me over the pipes.
Post by lcowner on Jul 22, 2011 20:23:01 GMT 1
pm sent wez
Post by Deleted on Jul 26, 2011 13:42:43 GMT 1
i could be wrong but once i was told to be carefull of bikes that had a smaller front cog,was an old(cheap) trick for drag bikes to try and drop the time a bit, put some different forces on the motor,i could be wrong from memory but if anybody has anything to add about that im keen to hear it,never to old to learn.
Post by dredge3 on Jul 27, 2011 22:07:34 GMT 1
i could be wrong but once i was told to be carefull of bikes that had a smaller front cog,was an old(cheap) trick for drag bikes to try and drop the time a bit, put some different forces on the motor,i could be wrong from memory but if anybody has anything to add about that im keen to hear it,never to old to learn. It puts less force on the engine as its easier to move it
Post by 1260dave on Jul 27, 2011 22:32:32 GMT 1
i haven't had any problems with mine, you've just got to be a bit careful when you whip the throttle back, in 6th gear at 10 thousand revs my bike is doing exactly 100mph, it also drinks petrol like theres a major leek in the tank i'm gonna have another 2 weeks of fun on the 15 then the 16's going back on to see how i get on with that
Post by lcowner on Jul 27, 2011 23:08:17 GMT 1
i am running 16t front sprocket on my 4lo. i want to change it to give me more bottom end drive in the low gears.im not worried abot top end speed and dont mind loosing a bit.what do i need to do go up to 17 or down to 15 .i know i cud change rear sprocket but it suits me better at the mo to change the front............. A 250 rear sprocket is 41 tooth plenty available for a trial have u got 1 for trial paul? ;D
Post by 1260dave on Jul 28, 2011 21:57:01 GMT 1
hi paul i thought the 250 stud spacing on the rear sprocket was different to the 350, have you got hold a 15 tooth yet, and have ya got your bike together yet dave
Post by oldelsieboy on Jul 28, 2011 22:05:18 GMT 1
hi paul i thought the 250 stud spacing on the rear sprocket was different to the 350, have you got hold a 15 tooth yet, and have ya got your bike together yet dave A 250LC sprocket will not fit a 350LC wheel, as previously stated the bolt pattern is different. OEB
