Post by wiseric on Jul 12, 2011 20:02:00 GMT 1
I'm keen on getting the outside of my lc2 carbs done, but not sure how to protect certain areas ie the glass windows and other small holes. The intake and manifold areas I can block with wood or cork and the float bowls will stay bolted on (obviously with the internals removed). I was thinking of using silicone but will that remain in place as the last thing I want is frosted glass on the carbs. Anybody got any suggestions or experience with doing this?
Post by gazilla on Jul 12, 2011 21:28:17 GMT 1
They normally strip the carbs as much as possible ie jets etc but you may need to ask about the sight glass may just need to mask up.
Post by uncleelsie on Jul 15, 2011 20:55:05 GMT 1
i had mine done, wouldn,t do it again, the result was brilliant but, it took an age to get all the media out. would go for ultrasonic cleaning next time.
Post by wiseric on Jul 16, 2011 21:54:31 GMT 1
Well I eventually found a place in Watford, the chap was very helpfull and did them while I waited. He gave them a thorough clean as well. The silicone worked well and protected the glass and other areas nicely. ;D
